ABS wheel speed sensors changed but ABS light still ON
Results 1 to 9 of 9
Thread: ABS wheel speed sensors changed but ABS light still ON
    Mar 2008
    Quebec, Canada
    95
    It's all in the title ! LOL
    I went to my buddy the other day who has the scanner and it was saying the both wheel sensors in the back needed to be change. So I just changed both sensors, but the light is still ON. I cannot go see my buddy because he's out of town. Can I do something to make the light goes OFF ??
    Jul 2008
    Niles Il.
    10,101
    The ABS should reset itself, but have you tried unhooking the battery for a few minutes? Or the wiring to the rear sensors is damaged.
    '69 GTO drop top
    Mar 2008
    Quebec, Canada
    95
    Nope, I didn't think about unhooking the battery. I don't know about the wiring, the scanner told "LR ABS Wheel Speed Sensor Failure" and " LR ABS Wheel Speed Sensor Undervoltage".
    Jan 2005
    Fayetteville, NC
    9,436
    I recently had issues with my rear wheel ABS sensors. Took it to a local garage, they scanned it as the LR. So I replaced it. Light still on. So I took it back to them and they said that there was a problem now with the RR. The RR had already been replaced under warranty, so the original diagnosis of the LR made sense. So in the end, I don't know if it really was the left or right. I just paid them to do the RR (so if the light was STILL on, it'd be on them), and that fixed it. Maybe it was both. Unfortunately, the only part they could get was a Mopar part, which I wasn't interested in using, but that's all that was available.
    According to the service manual, the ABS light will clear after all sensors register 15 MPH. If the light is still on, there's still a problem somewhere.
    Oct 2008
    2,470
    43
    I am beginning to wonder if the ring on the hub may be at the root of some of these problems. I have a similar problem that causes the ABS to come on and off sporadically, factory scanner said left rear was bad, but I cleaned and greased it and it worked for a while. Something else is going on. I wonder if worn bearings can cause enough wobble to cause such weirdness.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Mar 2008
    Quebec, Canada
    95
    Quote Originally Posted by tcwagner1 View Post
    My rear wheel bearings seem fine ! I checked both of them and I don't see any wooble or something else wrong with them.
    I'll need to put the scanner on again !!
    Apr 2010
    2
    Hi from the UK.
    I just changed a faulty front ABS wheel sensor on my 2001 chrysler voyager, I posed a thread earlier this year explaining how to test the sensors. Anyhow the new sensor cost me $36 from Ebay (USA) and when I fitted it the light went off after approx 1/4mile of driving. That was three months ago and it's been off ever since.
    I doubt the problem is with your tone wheel (the bit on the driveshaft) the rears are inside the hub and well protected from the elements, the fronts can get corroded though. Most likely a broken wire some where.
    Unplug the suspect sensor with the ignition turned on and one of the wires should have approx 9V DC supply to the sensor (measured to the chasis ground)
    Good luck
  10. The Following User Says Thank You to matgriff For This Useful Post:
    Pascal_82(08-26-2010)
  11. #8
    Mar 2008
    Quebec, Canada
    95
    If there's no voltage going to the sensors, what could it be now ??
  12. #9
    Jan 2008
    SE Wisconsin
    13
    I had a wire to my rear passenger side that broke causing the light to go on. The wiring was under the front wheel well cover according to the dealer mechanic. Might want to check that.
    Bob
    2006 T&C Touring
  1. ABS wheel sensors
    By golfnut in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-05-2009, 11:12 PM
  2. Changed both O2 sensors...ouch!!!
    By tuckman in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-18-2009, 10:24 PM
  3. Anyone changed rear wheel bearing hubs?
    By mooman in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-21-2009, 11:36 AM
  4. Speed sensors during solenoid pack change?
    By thebrakeman in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-08-2009, 03:11 PM
  5. Speed Sensors- How many?
    By ufaa08 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 02-18-2007, 06:11 AM
