Just replaced the Throttle Position Sensor due to fluctuating RPMs at constant speed.
Replacing the TPS fixed this issue, but now the van idles at 1200 rpm. The TPS change was the only fix. Could this be a bad TPS or are some TPS's calibrated slightly differently (Auto Zone purchase). As far as I can tell the TPS was installed properly? Anything else to check to change idle setting?
Thanks,
Replaced by a 2000 Nissan Primera 2.0L Sport+
