Power steering fluid vs ATF+4
Results 1 to 7 of 7
Thread: Power steering fluid vs ATF+4
    Dec 2006
    1,106
    31
    Hi all,
    I need to add some fluid to the power steering on my van, but an not sure whether it should be standard power steering fluid or ATF+4. The fluid in there at present is red. I do know that the previous owner had warranty service work done that involved replacement of the two hoses and fluid to solve a "honk" problem from the power steering system, but I am on the road and don't have the paperwork to see what fluid they filled it with. I know that the normal fluid for this van is not ATF+4, but I would have thought standard power steering fluid would be amber, not red.
    - G
    1998 Grand Voyager @334,000mi, 3.3L FFV V6
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by greenlight View Post
    Hi all,
    - G
    I still have the steering 'honk'. I called the Chrysler dealer about it and spoke to the tech. He said to flush the system and use ATF+4. If it's red and work was done at Chrysler, then I'm 99% sure it's ATF+4. Power steering fluid is clear/amber. ATF+4 is what I'd put in. Some say the 3rd gen's use power steering fluid and not ATF+4 but if the tech at Chrysler told me that ATF+4 is recommended then that's what I'm using.
  4. The Following User Says Thank You to sideburns2009 For This Useful Post:
    greenlight(07-17-2010)
  5. #3
    Dec 2006
    1,106
    31
    Quote Originally Posted by sideburns2009 View Post
    I've noticed the "honk" two or three times in the last year or so, but apparently the Chrysler service done on the van early in its life pretty well solved the problem. I found two TSBs for the issue, both of which seem to specify standard Mopar power steering fluid, not ATF+4. Perplexing....
  6. Remove Advertisements
  7. #4
    Nov 2008
    DeSoto County, MS
    2,926
    Check the date on the TSB's. It was probably before ATF+4 was being used in Chrysler's power steerings systems. Power steering is essentially just a hydraulic pump and transmission fluid is a hydraulic fluid and works fine. Mine is probably a 50/50 mix between the 2 (power steering fluid and ATF+4) and has been fine for 2 years or so.
  8. #5
    May 2006
    New Hampshire
    8,366
    Hi all,
    - G
    Back in 2006 the power steering on our 1998 DGC was getting a little noisy so I too was faced with the ATF+4/Power steering fluid conundrum due to noise. I ended up evacuating as much of the old fluid out of the reservoir and refilling the system with ATF+4. The process quieted the steering down considerably but not completely; I'd say it knocked off 90% of the noise and that was good enough for me. I did this when the van had just over 100,000 miles on it. When I sold it with 180,000 the system was still operating perfectly and (mostly) quietly with no leaks or other ill effects from the ATF+4.
    2012 VW GTI (6-Speed manual)
  9. #6
    Jan 2008
    Nova Scotia, Canada
    16,443
    Red = ATF+4, other power steering fluid is amber. ATF+4 is good, only problem is finding ATF+4 at the smaller gas stations. WalMart carries it and most service shops will as well. So, color match and top up with ATF+4.
    2007 GC SXT - Magnesium - S&G - 3.8L - 167,000 kms
    2002 GC Sport - Stone White - 3.3L - 349,900 kms
    2003 Jeep TJ Sport - 4.0L - 275,600 kms
  10. #7
    Jun 2009
    Jefferson City, TN
    3,051
    I've done my homework on this subject and this is what I have found. If you have a repair (such as a rack replacement) that causes you to lose most/all of the fluid, Chrysler recommends to refill the system with ATF+4 no matter the year of van. So if you had major steering work done at a Chrysler dealer, that is what happened. Also if you want to flush the system and refill it with ATF+4, that is not a problem either.
    Jeff
    Current:
    Previous minivans:
  1. power steering fluid
    By highe in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-09-2010, 11:32 PM
  2. power steering fluid
    By tooltime in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-25-2010, 06:47 AM
  3. Mopar Power Steering Fluid vs ATF+4
    By MBCT in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-03-2007, 02:29 PM
  4. Power Steering Fluid
    By caravantough in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-16-2004, 02:50 PM
