Whats the fuel pressure specs?
Results 1 to 9 of 9
Thread: Whats the fuel pressure specs?
    Mar 2009
    16
    What's the fuel pressure supposed to read at idle? I hooked up my fuel pressure gauge to diagnose a harder to start/stumble issue and I read 61psi. My repair manual says 49 psi. That got me wondering if the fuel pressure regulator is faulty. I searched thru this forum and I only found 1 reference to fuel pressure and that post stated something like 59 psi+/-5.
    Sooo
    #1 Whats the pressure supposed to be at idle?
    #2 Anybody ever have the pressure regulator go bad?
    Thanks to all.
    2001 GC Sport 3.3L 133,000 miles From eastern Iowa
    May 2010
    8
    I dont recall seeing pressure higher than 50, but I have only checked my 5.2L engine. for a hard start and stumble, I would clean the throttle body and also the IAC valve. (Idle Air Control) it's cheap to clean (carb cleaner and rags), doesn't take too long, and can't hurt.
    Apr 2009
    Empire State
    3,905
    as per factory service manual:
    SPECIFICATIONS
    FUEL SYSTEM PRESSURE
    400 kpa 34 kpa (58 psi 5 psi)
    so your reading sounds good..
    Apr 2007
    SoCal
    5,296
    Yup. 58 +/- 5 for a 4th generation van. 49-55 for a 3rd generation van.
    Mar 2009
    16
    Thanks guys!!! Throttle body is clean, time to look at the IAC.
    My Haynes manual which covers 96-2002 vans specs out 49psi. Time to make a correction in the manual.
    Jul 2008
    Niles Il.
    10,101
    How are your spark plugs? They could be fouled or worn causing hard start and an occasional miss.
    '69 GTO drop top
    Mar 2009
    16
    Took the IAC out and cleaned it up. It was really not that dirty. I put new plugs and wires on it when the van had 95,000 miles on it.(seems like only yesterday) Its got 133,00 now.
    I guess what bothers me the most is twice I've driven to the local convienece store. Less than 1 mile. When I come out, I back out of my parking space, put it in forward and the engine stumbles badly-like I'm surprised it didn't actually stall kind of stumble. Engine runs great all other times.
    Apr 2009
    Empire State
    3,905
    just a wild guess, but could be your O2 sensors.. (they are supposed to help PCM adjust the mixture..)
    to check them out, you need an OBD2 scanner that displays their output (preferably chart format) - both upstream and down..
    could also be the temp sensor (if the engine warms up, but coolant level is low/sensor is acting up - cold start will flood the engine..)
    Jan 2010
    winterville, GA
    221
    If it only stumbles immediately after hot start just ignore it.
    '87 Caravan LE 3.0, '91, '92, '93, '94 Grand Caravan LE 3.3
    '02 T&C Limited 3.8, '09 T&C Limited 4.0
  1. 05 T&C fuel pressure
    By ATOMANT in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-19-2010, 10:42 AM
  2. Fuel pressure regulator
    By aKids2003_DGC in forum The Fireplace
    Last Post: 05-20-2010, 07:53 AM
  3. fuel filter and pressure release
    By mrb641800 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 05-15-2009, 07:20 PM
  4. Whats your Tire Pressure?
    By IssaquahWA1979 in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 09-08-2008, 06:45 PM
  5. Fuel Pressure Release
    By hobbit91 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 11-09-2003, 02:20 PM
