2010 T&C Touring 3.8L - Dashboard Alert to change oil, at 5500miles
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: 2010 T&C Touring 3.8L - Dashboard Alert to change oil, at 5500miles
    Feb 2010
    7
    Is that just an automated reminder, or does the engine have sensors that are telling me the oil needs changing, like on my BMW.
    If so, why would it need changing at this interval? I had the oil changed at 2900, even though the manual says 6k, cause thats what the dealer told me to do, and they gave me 10 coupons for 15 dollar oil changes for the first 30k miles anyway so why not, its the same cost (half price, 2x as often).
    Should I be concerned about this alert? I called the dealer and they just told me to bring it in (of course, what else would they say, lol)
    May 2006
    New Hampshire
    8,368
    Quote Originally Posted by S.A.M.2010 View Post
    A few comments:
    • Your BMW does not have sensors that test the quality of the oil per se, it simply measures the amount of fuel used since the last reset of the OLM system (Oil Life Monitor), and infers the condition of the oil from that.
    • My understanding is that the Chrysler OLM is not quite so sophisticated and it really errs on the side of caution.
    • FWIW, it is my bet that your dealer didn't reset the OLM system in your van when you brought it in for the 2,900 mile oil change and that's why its recommending the change now.
    Dec 2008
    225
    3
    This topic has been beaten to death before.
    Check it out:
    http://forum.chryslerminivan.net/showthread.php?t=11860
    Current: 2012 Mazda 5, 2012 Mazda3 SkyActiv
    Previous: 2011 Grand Caravan, 2009 Grand Caravan SE, 2002 Grand Caravan Sport and several other Chrysler vehicles
    Feb 2010
    7
    Quote Originally Posted by JOEMAMA View Post
    Check it out:
    Thanks! I figured it had, but couldn't find it. My apologies for the extra thread.
    Dec 2008
    225
    3
    No worries - welcome to the forum!
    Jun 2009
    Jefferson City, TN
    3,051
    If you use your van for short trips or in city driving, the oil change reminder will come on about every 3,000 miles. It does not have sensors. It calculates engine duty cycles, it also calculates some criteria during those engine duty cycles, and makes an estimated guess on when to change the oil based on that data. The light usually comes on the first time around 3,000 miles or so. Seems like they start to lengthen out after that if you use your vehicle for more than just short trips. If you were my customer I'd tell you it's up to you. Your van thinks the oil needs to be changed based on the logic explained above. If you want to wait till it has been 3,000 miles since your last change, that should be ok as well.
    FWIW, IMO the first oil change should always be done early. Any metal or grit that has came loose is in that first oil filter. The quicker you get it out, the better. I've only had one new car, a 2007 Ford Focus. I performed the first oil change at 2,000 miles, even though it was not recommended till 5,000.
    Jeff
    Current:
    Previous minivans:
    Feb 2010
    7
    Quote Originally Posted by jgbat View Post
    The thing is, I did the first change at 2900, and there was no indicator, now 2600 miles later the light comes on, at 5500, which is when it should come on if the system was never reset after the first change, which is the most likely thing that happened. I'll get it done this week and then I think I'm going to wait for it to come on again or 5k miles, whichever comes first to get it changed. Seems like every 3k is way over kill from what I read in all the other threads on this topic. I'm only keeping the van 3-4 years, so I just want to make sure I keep the warranty valid, 1k before recommended in the manual at the latest will surely do that.
    Jun 2009
    Jefferson City, TN
    3,051
    It will. All I'm saying is I have seen them come on at like 2800 miles. I've also seen the thing not get reset. Which could be your issue.
    Jeff
    Current:
    Previous minivans:
    Dec 2008
    225
    3
    Can you reset the oil change indicator if it hasn't come on?
    Jun 2009
    Jefferson City, TN
    3,051
    Yes. But if it was not on, the person may have not thought to do it.
    Jeff
    Current:
    Previous minivans:
  1. Thinking about a used 2010 T&C touring
    By abbysdad in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 05-29-2010, 10:10 PM
  2. Looking to buy a 2010 T&C Touring
    By sat22 in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 04-27-2010, 11:41 PM
  3. 2010 Touring Hum and Highway Speed
    By mr_gecko in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 04-27-2010, 11:15 AM
  4. ***** hit and run alert *****
    By sousa632 in forum The Fireplace
    Last Post: 07-25-2009, 05:42 PM
  5. FRAUD ALERT: RBC Canada Alert
    By Site Administrator in forum Computers & Tech
    Last Post: 06-11-2004, 11:50 AM
