Power Steering problem
Results 1 to 10 of 10
Thread: Power Steering problem
    May 2010
    4
    Car failed the MOT due to power steering not working (needed 2500 rpm to get it to work) i replaced the pump and it was working fine. I passed the MOT and i had to turn round somewhere and done a full left lock and heard a wierd screech
    Now my power steerring not working again, i was told by someone they reckon its the valve on the power steering rack..... where would this be located and is that the problem or could it be something else
    Any help would be much appreciated thankyou
    I have a 97 Chrysler voyager 2.0
    Feb 2007
    Lancashire, UK
    913
    2
    It sounds like 'someone' was right.
    I used to have the same problem with my van. Unfortunately, the steering box valve cannot be overhauled or replaced. You will have to change the complete steering rack.
    I got one from a breakers yard for 100 then spent a day swapping them over.
    '97 Chrysler Grand Voyager 3.3 LE (UK Model) , 167,000 miles. Dual Fuel Petrol/LPG. Tow Pack.
    Now sold. New owner is using as a project ! Replaced by a 2000 Nissan Primera 2.0L Sport+
    May 2010
    4
    funny thing is took it for a long drive and the power steering started working, worked for couple of days then wont work again.
    Sep 2009
    NJ
    326
    48
    Have you changed out the fluid?
    Currently Abusing: 1996 Dodge Grand Caravan ES 3.8L 225,000 miles (4th tranny)
    Other Rides:
    2001 Lexus ES300 44,000 miles << just picked it up!!!
    2010 Lexus RX450H 27,000 miles
    2000 Lexus RX300 AWD 164,500 miles
    2011 Lexus IS-F 6,000 miles
    Retired cars worthy to mention:
    89' Toyota Van- 296,000 miles
    92' Toyota Corolla- 232,000 miles
    94' Toyota Camry XLE- 189,000 miles (gave it to my cousin; still running strong though)
    Feb 2007
    Lancashire, UK
    913
    2
    Quote Originally Posted by mugsymo View Post
    Mine would do the same. You probably have small pieces of rubber seal getting jammed in the steering valve.
    Most worrying thing is, it usually failed at low rpm. Like when turning a corner in town with the throttle closed.
    Not only would the steering kick back hard enough the sprain your wrist, but the sudden extra load on the PS pump/serpentine belt would stall the engine - so no power brakes either.
    Oct 2008
    2,469
    43
    For what it is worth, I read somewhere you should never hold the steering in full turn, left or right, for more than a few seconds as it will damage the unit. I don't know what it does, but that could be what triggered your problem. One of the real mechanics here can probably weigh in on what extended lock does and to what.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by tcwagner1 View Post
    It does nothing to anything unless the pressure relief valve is clogged which is very unlikely to happen. Or on cold days avoid full lock witht he vehicle not warmed up. I had our durango at full throttle at full steering lock on a bitterly cold day (around 5 degrees) and burst one of the power steering hoses. Man that made a mess.
    '69 GTO drop top
    Sep 2009
    14
    You NEVER want to hold the steering wheel against the stops, hot or cold. Used to work for a steering supplier to Chrysler in the late 90's. Some of the pumps will fail in as little as 15 seconds. The pressure relief valve recirculates the fluid directly to the pump (say HOT fluid) and can trash the pump.
    May 2010
    4
    Thankyou for the useful information everyone, when we replaced the steering pump we forgot to put in the new valve that you usually find underneath the pump..... could that be part of the problem or is it the fact we used standard powersteering fluid
    Oct 2008
    2,469
    43
    I believe I read that in the owners manual for my 05, but it is an 06 manual. Like I said, I don't know why it said that, but I took note of it.
    2000 Caravan 2.4l
  1. Power Steering Problem - What Do You Think?
    By Dodgeboy77 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-27-2010, 02:33 PM
  2. 02 T/C Limited Power steering problem
    By rabbithound in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-10-2009, 05:49 PM
  3. Problem with power steering - binds up at low speeds
    By hubbyofTCdriver in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-21-2008, 01:18 PM
  4. Problem with belt tensioner and power steering hose.
    By UTmeetsHALO in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-18-2007, 01:30 PM
  5. 2001 Grand Caravan Sport power steering problem
    By TCP in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-19-2005, 01:38 PM
