Fuel Pump Longevity
Results 1 to 10 of 15
Thread: Fuel Pump Longevity
    Mar 2007
    Arizona & Washington
    216
    Fuel Pump Longevity
    2003 T&C with 86,000+ miles----What is the consensus regarding fuel pump reliability? Would it behoove an owner to change it at some milestone?
    Dec 2008
    1,985
    The fuel pumps in these dont seem to be an issue....now the Fords and GMs,thats another story...
    My 88 Aries had 94,000 miles when I bought it,it was still the OEM pump when I changed it.It was made by Bosch.The new Bosch are now made by Walbro (makers of the horrid Lauson/Tecumseh carburetors).
    Jan 2009
    41
    My 2001 T & C fuel pump crapped out at 92,000.
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    I changed my 1990 after 120kmiles, that one failed (actually fell apart in the tank) within a month, and again at 190kmiles. The "fuel filter" is now a part of the pump assembly on newer GEN's, whereas mine has a "pre-screen" at the pump, and an in-line filter half way to the engine. So if you want to be "pro-active", instead of "re-active", consider around every 100kmiles (pretend it's a "timing belt").
    Still Going Strong
    May 2006
    New Hampshire
    8,368
    We've now had three DGCs that have gone 140,000 (and counting), 170,000 (traded in), and 180,000 (and counting) miles without a single fuel pump or fuel filter issue. My philosophy, if it fails, I'll fix it; in the meantime I couldn't be bothered to worry about it.
    Jul 2008
    Niles Il.
    10,101
    Keep gas in the tank and never worry about it. The people who run it empty and only throw in $10 at a time are more likely to need a pump. I fill mine up and run it down to empty, that practice helps the pump live a long life.
    '69 GTO drop top
    Oct 2009
    Atlanta, Georgia
    125
    1
    If it was a GM product, I'd say you are past due. I've owned almost dozen Chrysler products from years 1990 to 1999. Never had a single issue and I rarely ever see them go out at the shop. As long as you don't run it dry and on empty all the time (really hard on a fuel pump) it should last a good long time.
    2002 Chrysler Town& Country LX "The $250 Blue Bomber"
    3.3L V6 Flex Fuel, 215,000 miles.
    Retired:
    1994 Dodge Caravan Base
    3.0 V6 5-Speed
    Mar 2007
    216
    Fuel Pump Longevity
    Thank you all very much for those helpful comments.
    Oct 2008
    3,508
    I can understand the "If it ain't broke don't fix it", however, If I'm going on a trip and have that many miles on a known part that is prone to failure after so many miles/100k+ (and not easy to replace "on the road"), I'd seriously consider being "Pro-Active", than "Re-Active". Just my opinion. Same goes with T-Stats and Radiator caps.
    My last one gave me a real run. It would work fine, until it got "hot" (even with a full tank -- something about 120deg Summers), then the fuel pressure would drop and all I could do was "idle", if I was lucky. Let it cool down (an hour or more), and I could drive for another 30 or so minutes. Initially, I thought it was one of the sensors on the tranny. Worked fine, after changing the sensor (for an hour), then I was on the side of the highway, miles from any service .......
    Still Going Strong
    Mar 2010
    16
    I have the original pump and my van has 123000 on the clock, Its a 2002.
    2002 Limited Town and County, 2005 Touring Pacifica,
    Use to own 2005 PT Cruiser
  1. Water Pump Longevity
    By DaveKG55 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-22-2010, 03:50 PM
  2. 93 Fuel pump
    By tloughrin in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 03-23-2010, 03:15 AM
  3. is it my fuel pump
    By joshockey in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-24-2008, 11:07 PM
  4. Fuel pump
    By gibbelstein in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 04-10-2008, 01:24 PM
  5. fuel pump?
    By cf1 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 02-02-2008, 10:49 AM
