Oil Pressure
Results 1 to 5 of 5
Thread: Oil Pressure
    Oct 2008
    7
    Oil Pressure
    2000 Grand Voyager, 3.3L engine, 118,00 miles. OIl pressure warning light on when idling at a traffic light, about 750RPM. When I accelerate, warning light goes off. I'm thinking I have something restricting oil flow? Oil pump going bad? I just changed the oil today (wife first noticed light coming on yesterday).
    Jan 2005
    Fayetteville, NC
    9,436
    It's most likely a lazy oil pressure sensor. It's a cheap part, and the probable fix.
    Apr 2010
    78
    Or, if it's had less than good maintenance over the years, it could be worn bearings, worn oil pump, or otherwise loose tolerances that "bleed off" oil pressure. If it was me, I would install a mechanical oil pressure gauge in addition to replacing the existing sending unit. That way you will know for sure what kind of oil pressure you are getting.
    2000 Plymouth Voyager - Original 2.4L and 31TH - 210,000 miles
    1997 Dodge Caravan Sport - Original 3.3L and 41TE - 113,000 miles
    Oct 2008
    7
    I've been changing the oil regularly, I've had the van for 5 - 6 years now. To check the pressure with a reliable gauge, remove the sensor and install the gauge, the sensor is next to/above the oil filter?
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by camp800 View Post
    That is the way to check the pressure.
    You can probably just get away with changing the sensor though. They are very common to fail on Chrysler's and you may even find that it has started leaking a bit too. Usually they have oil in the electrical plug when they start to go bad.
    '69 GTO drop top
  1. Oil Pressure
    By wavedude in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-25-2010, 07:28 PM
  2. AC Pressure
    By 2002CaravanSE in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-01-2009, 03:00 PM
  3. Low oil pressure
    By tloughrin in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 04-10-2009, 03:26 PM
  4. Where is A/C low-pressure cap?
    By dawnstar in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-07-2008, 09:40 PM
  5. Oil leaks under pressure
    By aterrd in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-15-2008, 03:09 AM
