Does this sound like an inner CV joint symptom?
Results 1 to 8 of 8
Thread: Does this sound like an inner CV joint symptom?
    Apr 2008
    36
    Just put a new tranny in the van, a '98 Dodge Caravan Sport 3.3. It has 203k miles on it, with the original driver's side axle, and a 2 year old reman axle on the passenger side. When I put the car in reverse and give it some gas while hitting the brake, I get a thump/clunk coming from the passenger side. The motor mounts are good with the exception of the passenger side mount, which I'm replacing this weekend. I've checked the ball joints and tie rods, which have very little if any play in them. Could it be my reman axle already going bad on me? What else should I check?
    Jun 2009
    St. Cloud, MN
    1,667
    One thing at a time. Change out that bad motor mount first, then recheck for symptoms. The bad motor mount could easily be all that is causing that noise.
    DAN(husband of member STEPHANIE)
    2000 Chrysler Town & Country Limited - Dark Charcoal Metallic with chrome trim, taupe leather interior, loaded. In need of rust repair on rockers and liftgate. Now enjoying the new family mommy-mobile!
    Knowledge can never be wisdom without experience.
    "Your experience is a commodity."
    "Opportunity is not a lengthy visitor."
    DRIVE = LOVE
    Jul 2009
    901
    8
    This may sound like it's out of left field, but just a thought - my buddy had the exact same symptom with his Nissan Murano, and was this close to buying a new axle, until he found a tip on the internet - the tip was to loosen and retighten the hub nut. We tried it, and as soon as we loosened the hub nut, the clunk went away. We cleaned the interface between the axle and the hub, retightened the hub nut, and the problem has gone away for good. May be worth a try, it's easy enough to check.
    Leon
    '97 Town & Country LXi
    Sep 2009
    NJ
    326
    48
    Wow! I'm so suprised! I have the same damn problem and I was just about to post on it. But in my case i have a new drivers side axel replaced about 1 month ago but the problem still pesists. I also replaced the tranny mount all other mounts are in perfect condition.
    P.S- Should i make a new thread for my problem or just keep it here? I don't want to hijack this thread.
    Currently Abusing: 1996 Dodge Grand Caravan ES 3.8L 225,000 miles (4th tranny)
    Other Rides:
    2001 Lexus ES300 44,000 miles << just picked it up!!!
    2010 Lexus RX450H 27,000 miles
    2000 Lexus RX300 AWD 164,500 miles
    2011 Lexus IS-F 6,000 miles
    Retired cars worthy to mention:
    89' Toyota Van- 296,000 miles
    92' Toyota Corolla- 232,000 miles
    94' Toyota Camry XLE- 189,000 miles (gave it to my cousin; still running strong though)
    Jul 2008
    Niles Il.
    10,101
    Could be the reman axle. I know I got the "good" A1 cardone rebuilt axles, but they are bad a few years later with maybe 30k miles on them. I'm just waiting for when they get worse to go exchange them under warranty. I believe they get a lifetime warranty.
    '69 GTO drop top
    Sep 2009
    NJ
    326
    48
    robk46- did you figure out the problem?
    Other Rides:
    Sep 2009
    NJ
    326
    48
    Update: I had the same problem, as mentioned above. I recently changed my brakes, and in the process i realized that the front passenger side caliper was loose, I opened the screw with two fingers, no wrench required. Good thing, it didn't cause any damage.
    Other Rides:
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Quote Originally Posted by hypervish View Post
    Go ahead and post here, since it's the same / similar problem / symptoms. Reduces the amount of duplicate problems threads .......
    BTW, When you get reman axles, consider checking how much grease is in them. Some MFR's expect you to grease them before installing them, hence, they'll fail early without you taking the time to add grease.
    Quick way to check them is to grab the axle and rotate it with your hand. If it "clicks", you have wear and might consider replacing them.
    Still Going Strong
  1. Inner CV Joint Rebuild Kit
    By mdelorie in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 04-30-2012, 05:21 AM
  2. Possible C/V joint or ?
    By oldchina in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-22-2009, 10:50 PM
  3. cv joint help
    By civiclifer in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 09-03-2008, 12:59 PM
  4. Does this sound like a CV joint going?
    By ElGeraldo in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-03-2008, 11:55 AM
  5. Squeal/chirp symptom
    By Keith010 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-02-2008, 10:39 PM
