How to identify a bad Transmission Solenoid?
Results 1 to 10 of 11
Thread: How to identify a bad Transmission Solenoid?
    Sep 2009
    Rapid City, SD
    40
    If the Transmission Solenoid is bad and needs replacing what would be the signs... fault codes? bad shifting? check engine light?
    Interested to learn just in-case. Thanks.
    03 T&C AWD Limited, 102K miles
    1990 Ford Taurus GL, 2nd owner & only 53k miles
    Fun Stuff: 1977 Lotus Esprit S1 with 30K original miles
    Jul 2009
    Tunkhannock, PA
    430
    Any or all of the above
    A deeper scan (drbIII) can further diagnose what exactly the issue is.
    Transmission shops and Chrysler dealers should have this tool.
    2005 Kia Sorento LX 4x4 44,000mi
    2003 Chrysler T&C Limited 3.8l AWD 145,000mi Traded in 9/14/11
    2000 Dodge Stratus ES v6 179,000 sold 7/2011
    Jul 2009
    Plano, TX
    180
    P0700 is the initial code for a trans problem, and the scanner ratsttam mentioned is needed for real diagnosis.
    If the the solenoid pack is malfunctioning, you may be in limp mode (not able to go above 2nd gear and 35 mph).
    I had my TCM go in my 01 Chrysler Sebring Convertible a couple years ago. CEL came on and the car went into limp mode. Part cost about $100 or so on the 41TE transmission.
    - Kevin
    2009 Bright Silver Metallic Dodge Grand Caravan SE 3.3L v6 54k mi
    2001 Stone White Chrysler Sebring Convertible Limited 2.7L v6 102k mi
    "If you had access to a car like this, would you take it back right away?"
    "Neither would I!" - Ferris Bueller
    Jul 2008
    Niles Il.
    10,101
    Slow or clunky shifting has always been the reason for me to replace the solenoid. Usually fixes it too. Also leaking from the pack is another reason for replacement.
    '69 GTO drop top
    Apr 2009
    Bronx, New York City.
    576
    Yea, mine was slowly leaking red fluid that's how i found my problem.
    Silver 2002 Chrysler T&C EX 3.8
    Just hit 100,000 miles and counting.
    Jan 2008
    Nova Scotia, Canada
    16,444
    The question has been asked before per this Thread.
    This site will help you understand your transmission better as to its operation. Another site.
    2007 GC SXT - Magnesium - S&G - 3.8L - 167,000 kms
    2002 GC Sport - Stone White - 3.3L - 349,900 kms
    2003 Jeep TJ Sport - 4.0L - 275,600 kms
    Dec 2012
    1
    your thread link is bad.
    Oct 2009
    Atlanta, Georgia
    125
    1
    Solenoid packs usually fail internally due to contamination, metal bits in the fluid clog up the tiny screens. Most of the time they just leak from the front cover, and they need to be replaced.
    2002 Chrysler Town& Country LX "The $250 Blue Bomber"
    3.3L V6 Flex Fuel, 215,000 miles.
    Retired:
    1994 Dodge Caravan Base
    3.0 V6 5-Speed
    Jun 2007
    305
    42
    And, when you absolutely, positively want to change the sol pack..... go here:
    http://forum.chryslerminivan.net/sho...+solenoid+pack
    It's sooooo simple.
    2002 T&C Ltd.
    White w/Gray 145,000+ miles
    1997 T&C Lxi
    Green w/Tan 225,000 before sold
    Aug 2012
    320
    I can tell you the story of my solenoid pack going:
    My mom would take the car about 40km to work everyday. One day when i was getting a ride, i noticed the car would have trouble shifting (late, sloppy, etc.), the following day, the van quit shifting at all and we were stuck in 1st gear on roads with 80km/h limits. Luckily the size of the engine allows it to reach higher speeds at lower gears, and averaged abotu 4krpm daily, did burn through a ton of gas though.
    Fixed it by changing the solenoid.
    I knew nothing about cars back then, so couldn't give you more details on the situation than that.
  1. transmission solenoid pack is leaking transmission fluid
    By mooman in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-10-2016, 02:57 AM
  2. Transmission solenoid manufacturer
    By mva5142 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-19-2010, 06:51 PM
  3. transmission shift solenoid
    By codgerdog in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-21-2009, 11:39 AM
  4. transmission solenoid pack
    By DerekP in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-06-2008, 05:26 PM
  5. Transmission shift solenoid?
    By MN99TC in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-04-2007, 04:13 PM
