Can you Lose Brake Fluid without there being a leak?
Results 1 to 8 of 8
Thread: Can you Lose Brake Fluid without there being a leak?
    Dec 2009
    Jersey, gotta get out of Jersey
    83
    So I took our company Chevy for a spin, and i had to really ut the peddle down to stop. Despite company policy I took a look at the brake reservoir nearly empty, the first half was bone dry, and the second half had a little bit left. Service on the fleet is a bit lacking, in the two years since its last tune up and oil change, can the fluid just disappear without a leak, or is their a deffinte leak I should report to fleet maintance?
    1995 Dodge Caravan FWD 3.3L
    Paul 1991-2010 I thank you everyday I have for the hobby you got me into
    Oct 2008
    2,469
    43
    Simple simple. It is pad wear if there are no leaks. As the pad wears, the piston goes out more and it requires more fluid to fill the caliper. That is why you don't fill the res. before you do a brake job, because as you compress the pistons to accomodate the fat pads, you force fluid back up into the res. If it is full, you should drain it out before you do the brake job, then fill back after the job is done.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Apr 2009
    Windsor ON
    790
    There could be another case, when the master cylinder leaking into the vacum booster.
    who left the dodge out?
    Plymouth Voyager 1999 LE 3.8
    Dec 2009
    83
    Well I know I shouldn't, (but if i submit it for repair I won't see it again all summer) but If i just bleed the brakes since half of the system went dry, and refilled I should be fine?
    Jan 2008
    Nova Scotia, Canada
    16,496
    If you have air in the system, it should be bled out. If you have ABS brakes, bleeding may not be so simple and may require a scan tool to cycle the solenoids in the ABS modulator, to facilitate bleeding. That was mentioned in another Post today.
    Could have the brake fluid topped up so you can monitor what's happening. Brake wear will contribute to a lowering of brake fluid in the master cylinder reservoir but I suspect something else is going on as well. How many miles on the brakes?
    Brakes are nothing to fool with and since you have already said you had trouble stopping, I suspect work is needed on them. Be safe rather than sorry.
    Mar 2009
    Temporary Insanity, PA
    1,149
    Just report it to the company and get another vehicle in exchange for it.
    Regardless of whether it's your favorite vehicle, the company has their policies in place for a reason, and if something happens that can be linked to the brakes, and it can be proven that you serviced them against company policy, they can probably fire you and force you to pay for the damages caused by the incident, as well as any repairs to the vehicle deemed necessary to negate the "work" you did.
    It's not worth it to keep your "favorite" vehicle.
    However, the company would have no grounds for dismissal if you'd simply checked fluids, as this is actually a part of operation of a fleet-based motor vehicle. A basic check of all systems involved in the safe, reliable operation of the vehicle in question should be performed before ANY duty related operation occurs. I believe the NHTSA has a report on it, but I don't have the gumption to search for it. Regardless, if they were to chastise, dismiss, or otherwise punish you for doing so, you'd have grounds to file suit against them.
    On their end, though, and especially since you're (probably) not a certified mechanic, and surely not employed in capacity as a maintenance technician with the company in question, you should just notify them of what has been done thus far, and let them take over from there.
    2000 Caravan - "Cara" - 2.4/31TH - 128,XXX
    0w30 Mobil1 Syn, SRT-4 oil filter, roof rack delete.
    Apr 2006
    Dearborn, MI
    2,592
    Quote Originally Posted by F BULLDOG View Post
    or it could of been like my dad's van, where the master cylinder was leaking, but it wouldn't leave a puddle behind either. it wasn't leaking into the vacuum booster, I know this because the inside of that was bone dry, but everything below the master cylinder was wet, and it had leaked all over the p/s rack, which at first made me think that the rack was leaky.
    Im 26 and my parents own a 2014 Grand Caravan R/T (3.6l, 22k miles) 2007 Dodge Caliber SXT (1.8l 87k miles 5spd), a 2001 Chrysler PT Cruiser ((which is mine) 2.4l 125k miles 41TE), and a 2000 Ford Mustang base (3.8l, 4 spd auto 30k miles)
    Oct 2008
    2,469
    43
    I used to have a boot store and repair boots. Once I sold a pair to a fellow I knew and a week later he was in the store and hot. He pointed out on the foot of the boot, dots of dye had come off, revealing the yellow leather under the dark brown two-toning finish. He was sure the boot was defective, I assured him it was not, but that I would redye the boot to make him happy. I encouraged him to inspect his master cylinder in his old truck, since it looked to me like a spray of brake fluid had come out on top of his boot. He assured me that his MC was not leaking, but he would check. A couple of days later he came back in super apologetic, his master cylinder was sending out an atomized mist of fluid when he stomped it. I fixed it free and had a friend for life. But just pointing out another way you can leak fluid without finding an obvious leak. It would show up eventually somewhere, but you might run through two or three cobblers before you found it. Brake fluid is a great way to strip a boot.
    2000 Caravan 2.4l
  1. orange fluid leak
    By ffxigotenks in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-25-2010, 08:17 AM
  2. Pressurized Fluid Leak
    By cjhsa in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-03-2009, 03:31 PM
  3. Transmission Fluid Leak
    By Bikedad in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-22-2009, 12:07 AM
  4. Red fluid leak
    By wabash in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-16-2009, 01:55 PM
  5. Trans fluid leak 99 T&C Ltd 3.8
    By jrprich in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-23-2009, 11:35 PM
