$1000 for a leaky 2000 Voyager transmission?
Results 1 to 10 of 13
Thread: $1000 for a leaky 2000 Voyager transmission?
    Oct 2007
    67
    14
    Just need some advice. A reputable local Trans. shop wants $1000 to drop the trans and fix leaks in a couple of places. Does this seem correct? And if not, does any one know a reputable trans shop in Northern NJ?
    2000 Chrysler Grand Voyager
    3.3 v6 , 4 speed auto
    trailer tow prep
    Silver
    147,000 miles
    Mar 2010
    WV
    67
    It depends on what is leaking. If the bushing is out of the torque converter, dropping the transaxle and putting in a new seal won't fix it and you'll be paying for unnecessary labor.
    Axle seals and most else are accessible without dropping the transaxle, I think bare minimum you should get a 2nd opinion from another transmission place.
    Oct 2008
    Overland Park, Kansas
    779
    1
    Sometimes the pin that holds the spider gears in place works itself lose and as it rotates the pins cuts a tear in the bellhousing causing it to leak. They could tack the bolt in place and weld up the bellhousing then replace all the gaskets and seals and it'd be good as new and you wouldn't have problems again.
    02 Town & Country Limited FWD(Wife's)
    02 Grand Caravan Sport 3.3 FWD(Mom's, bought new)
    99 Suburban K1500 Vortec 350/4L60E(Dad's)
    95 Sierra C1500 TBI 305/5spd(Mine)
    Jul 2005
    NJ
    1,571
    6
    $1000 sounds like a proverbial boat payment.
    Apr 2009
    Empire State
    3,870
    define "couple of places"!
    Assuming you have 41TE - by the book, it takes ~6 hours of labor to remove the trans, change out the front pump seal and reinstall the trans back in the van... and ~12 hours to rebuild it (multiply the shop rate $/hr by time and add parts... ex: 6*$75/hr + $200 in parts = $650)
    You need to know exactly what the quote is for.. (complete overhaul, specific problem fix etc..) then you can decide 1) is the diagnosis likely to cure the problem & 2) is it worth the $..
    Jan 2008
    Nova Scotia, Canada
    16,494
    Quote Originally Posted by Armadillo View Post
    Could be correct, but sure doesn't sound like it's correct. What work is proposed, for what reasons, and how many hours of labour are involved?
    Always get a second quote to keep things competitive and to save money.
    Jun 2008
    387
    I have seen people paying 1000 for a trans pan leak and the hoses leaking. All of that can be done at home if you ask me.
    As somebody said, the guy told you what was leaking?
    Oct 2003
    321
    How much is it leaking and how many miles do you have on the transmission?
    If the leak is small, e.g. 4 oz per month and the miles are high, e.g. 140K miles, I'd just wait. The transmission will likely fail at about 150K miles and a rebuilt costs about $2K.
    To pay $1K to fix a leak would be a huge waste if you need a total rebuild soon.
    Oct 2007
    67
    14
    I happen to live in NJ where the labor rate is $90/hour.
    trailer tow prep
    Silver
    147,000 miles
    Jan 2008
    Nova Scotia, Canada
    16,494
    How many hours of labour are they quoting or did they not provide a breakdown? I would be requesting a labor / material breakdow so you know what you are getting.
  1. Transmission cooler leak - does it really require $1000 repair?
    By dmtstudio in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-21-2017, 10:03 AM
  2. Plymouth Voyager 2000 with 152000 miles - should I change the transmission fluid?
    By Plymouht2000 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-04-2010, 03:55 AM
  3. 2000 Plymouth Voyager, transmission crapped out
    By ret_marine2003 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-16-2008, 09:08 PM
  4. Ihf 1000
    By CMSS2007T in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-13-2007, 03:27 PM
