Transmission wont shift out of 2nd gear
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Transmission wont shift out of 2nd gear
    Apr 2010
    1
    I have a 2001 Chrysler Town & Country mini van, It will not shift out of 2nd gear, as a matter in fact it starts in 2nd gear. Reverse works fine. I just changed the filter and fluid with atf+4, and replaced the shift solenoid. Just a guess. It still does not work. Any other suggestions?:
    Nov 2008
    DeSoto County, MS
    2,926
    Is the check engine light on? Does your speedometer work?
    Jan 2007
    North Carolina
    84
    What you describe is the "limp in mode" that your transmission uses when you have a problem. Unfortunately changing the fluid is unlikely to fix the problem. You will likely need to take it in for service.
  5. #4
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    These tranny's are "SMART" and can be scanned by any tranny shop. So, select 2 or more tranny shops and ask to get it scanned, get copies of the scans (printouts) and let us know what it says. May be something as simple as a bad wire, or corroded connector.
    Still Going Strong
  6. #5
    Oct 2008
    2,469
    43
    Be sure your radiator oil cooler is clear, if it will not pass enough fluid, it may not shift properly, but you have to tell us more. What motivated your changing fluid, sol, filter? Was it doing this before that moved you to change it? What model tranny and engine? Codes? 1st and reverse used to work on the same band, others on a different band. I believe that limp in is 2nd and reverse, but I could be wrong. Sounds like limp in mode, have you tried disconnecting the battery for 15 minutes or so and starting over?
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
  7. #6
    Nov 2008
    DeSoto County, MS
    2,926
    I'm still sticking to is the check engine light on and whether or not the speedometer is working. A lot of transmission related codes can be set to the PCM as a P0 code and retrieved with the key dance method or a scanner at autozone. Like input or output speed sensors and such. There will also be a PO code set to the PCM if there is a code present in the TCM, it says "transmission fault code set" or something along those lines, which turns on the check engine light as well.
  8. #7
    Apr 2009
    Empire State
    3,786
    make sure your TCM relay is in place (and 100% functional) and the wiring and plug on the solenoids is clean and tight... pull the IOD fuse for 10min and try again
    if that does not help,
    get it scanned for codes, and have "quick learn" performed on it if no faults are found..
    Whenever changing the solenoid assy, you should have the CVI's reset as wrong values can reek havoc on tranny operation
  9. #8
    Nov 2008
    DeSoto County, MS
    2,926
    You would only reset CVI's if the clutches were actually replaced with new ones. They have nothing to do with the solenoid pack.
  10. #9
    Apr 2009
    Empire State
    3,786
    Quote Originally Posted by sideburns2009 View Post
    it's up to the person who's changing out the solenoid assy, but I'm not making this up..
    Quote Originally Posted by FSM
    REMOVAL
    NOTE: If solenoid/pressure switch assembly is
    being replaced, the ªQuick-Learnº procedure must
    be performed.
    (Refer to 8 - ELECTRICAL/ELEC-
    TRONIC CONTROL MODULES/TRANSMISSION
    CONTROL MODULE - STANDARD PROCEDURE)
  11. #10
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by atoman View Post
    Yes, a quick learn can be recommended, not necessarily required and most people here who have replaced their pack haven't had it done, with no issue afterwards. Not a CVI (clutch volume index) reset. That (quick learn) is just a "help" or "boost" for the fuzzy logic that learns how we drive and shifts smoother afterwards. It provides temporary smoother shifts until how it's driven is actually relearned by the TCM itself. I didn't do a quick learn on my van when I changed the solenoid pack. The gears held out a little longer than they did before and it did shift different, but only for about 2-3 weeks. Nothing out of the ordinary, like when the van is/was new. Besides, it had limp-mode before the solenoid pack was changed, it was changed to attempt to fix the limp-mode.
    It could be as simple as input or output speed sensors, which would set a check engine code and one of the 2 would cause the speedo to fail as well, hence my original questions.
  1. wont shift out of first gear?!?
    By Justin in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-05-2013, 09:14 AM
  2. Help mini van transmission will up shift/down shift then wont up shift unless shut of
    By Ms54Coupe in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-28-2010, 12:59 PM
  3. Hard shift into first gear
    By 97voyager in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-21-2010, 10:31 PM
  4. Van wont stay running in gear and Reset Computer?
    By agunslinger in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-19-2010, 09:06 AM
  5. Whining with A/C + gear shift...
    By Jon7289 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-19-2009, 09:53 AM
