EBL Relay
Results 1 to 5 of 5
Thread: EBL Relay
    Apr 2008
    6
    EBL Relay
    I am trying to find out what the EBL Relay is that is located in my fuse box. I cannot find any info about it anywhere.
    Thanks.
    Feb 2010
    Auburn Hills, Michigan
    19
    Electronic Back Lite? Rear defogger grid? That's my guess.
    2004 Town & Country Limited (Butane Blue)
    3.8 litre engine
    All options except AWD and sunroof.
    93,000
    Mar 2008
    Southern WI
    381
    4
    Year? Make? Model?
    Pat
    08 T&C Touring
    Previous vans:
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
  5. #4
    Apr 2009
    Empire State
    3,786
    DESCRIPTION
    The rear window defogger (EBL) relay (Fig. 3) is a
    International Standards Organization (ISO)-type
    relay. Relays conforming to the ISO specifications
    have common physical dimensions, current capaci-
    ties, terminal patterns, and terminal functions. The
    rear window defogger relay is a electromechanical
    device that switches battery current through a fuse
    in the integrated power module (IPM) to the rear
    window defogger grid and switches battery current
    through a positive thermal coefficient (PTC) in the
    IPM to the outside mirror heating grids. The relay is
    energized when the relay coil is provided a ground
    path by the rear window defogger relay control in the
    front control module (FCM).
    The rear window defogger (EBL) relay is located in
    the IPM in the engine compartment. See the fuse
    and relay layout map on the inner surface of the
    cover of the IPM for rear window defogger relay iden-
    tification and location.
    The rear window defogger (EBL) relay cannot be
    adjusted or repaired and, if damaged or faulty, it
    must be replaced.
  6. #5
    Apr 2008
    6
    Thankyou.
  1. Where can I buy an NBS relay...
    By Ole Greaser in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-26-2009, 06:33 AM
  2. ASD Relay
    By 99voyager in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-20-2008, 05:35 AM
  3. A.c. Relay Id
    By U.S.P.S. in forum 1st Generation Chrysler Minivan: 1984-1990
    Last Post: 03-15-2008, 10:46 PM
  4. fan relay
    By tazzman in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-26-2007, 02:30 AM
