Location of Engine Coolant Temp (ECT) Sensor
Results 1 to 10 of 10
Thread: Location of Engine Coolant Temp (ECT) Sensor
    Aug 2009
    16
    Threw my first CEL today (cherry has been popped for this one) and got the code read from my local Autozone. P0128 which states the ECT sensor is bad or the coolant level is low. Coolant level is ok, but upon researching I am having trouble locating where this is. If anyone can provide the location that would be great.
    Jul 2008
    Niles Il.
    10,101
    I'm going to guess that you have a 3.3 or 3.8 engine. I believe the sensor is near the front of the engine by the thermostat area.
    '69 GTO drop top
    Aug 2009
    16
    Yes...sorry about that. I should know better, lol. Yes it is a 2006 3.8L v6
    Nov 2008
    DeSoto County, MS
    2,926
    The coolant sensor (ECT Sensor) is the two wire sensor that is next to the thermostat housing.
    (this shows the back side of the engine, as it's behind the ignition coil)
    Aug 2009
    16
    Ahhhh there we go. Thank you...once I can pull it in the garage I will take a look to find it.
    Thank you!!
    Nov 2008
    DeSoto County, MS
    2,926
    Quote Originally Posted by B-5 View Post
    Thank you!!
    No problem.
    Aug 2009
    16
    Bump this up for hints...this thing is a pain in the arse to get out. Have unplugged the 3 ignition wires and the sensor above it. To frustating for this day!!
    Dec 2009
    Indiana
    20
    I'm experiencing this code as well. I had to have the radiator replaced recently but the hoses and thermostat were not replaced. The thermostat seems to be working properly as the temp gauge does move a quarter way up from cold and then a little passed it. The sensor seems like it would be quickest and easiest to replace. Is there any type of reset needed after installing the sensor in order to get the check engine light to go off?
    Apr 2014
    3
    There is an app called torque that works with a small adapter that fits into your OBD port. The adapter is inexpensive and torque (lite) is free, There is a paid version that will do more but lite is all you need to reset fault codes.
  12. The Following User Says Thank You to joemama43537 For This Useful Post:
    fatalalbert(12-21-2016)
  13. #10
    Jan 2015
    TEXAS, USA
    3,155
    Quote Originally Posted by joemama43537 View Post
    Does it really took you over two years to reply to this thread?
    2012 Town & Country
    Current Minivans I own.
    LEVY --UNKNOWN MEMBER--
  1. Coolant Temp Sensor
    By gsmagnum in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-18-2010, 10:39 PM
  2. OBDC Readings - Do You Get Coolant Temp ?
    By mistypotato in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-28-2010, 04:52 PM
  3. Trans temp sensor/mount location?
    By RED04DGCLE in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-19-2008, 08:10 PM
  4. Where can I get an outside temp sensor?
    By rico in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-31-2007, 09:10 AM
  5. Outside air temp sensor location?
    By Curlyhead in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-07-2004, 12:28 PM
