Intermittent Brake Lite on when stopping.
Results 1 to 8 of 8
Thread: Intermittent Brake Lite on when stopping.
    Jan 2009
    3
    Question Intermittent Brake Lite on when stopping.
    I have a 2002 Caravan SE. When I stop, the brake lite comes on. Usually after I have taken the foot off the brake and started moving. It stays on for a couple of seconds and then goes out. Stops fine. I thought it might be trying to tell me that the the front disk brakes were low, and pulled the wheels.
    They are fine. No error codes on the regular ODBII. Any suggestions?
    Jul 2008
    Niles Il.
    10,101
    How is the fluid level and does the ABS work when needed?
    '69 GTO drop top
    Mar 2009
    Ontario, Canada
    100
    if i was to guess based on what you described either the master cylinder or booster is the cause.
    Jan 2009
    3
    Yes the ABS seems to be OK. No indications it's not. No lites. Fluid level
    seems OK.
    Jul 2008
    Niles Il.
    10,101
    How are the rear brakes as well? I know in our durango that the brake light used to come on occasionally when the rear brakes were worn. Rebuilding them took care of the light.
    '69 GTO drop top
    Oct 2007
    Vermont
    1,332
    Try adding a tablespoon of brake fluid and see if this solves the problem. This is a classic symptom of the fluid being a little low, low enoguh to trip the light.
    Apr 2009
    Empire State
    3,814
    Check your Parking Brake pedal/switch also...
    the "BRAKE" light is triggered by both - brake fluid level sensor and "hand brake" switch
    Jan 2009
    3
    Thanks all for your insight. Andyg, DASander and atoman were apparently correct. I added
    a little brake fluid and the problem seems to have gone away. Didn't think it was low, but
    apparently so. Thanks everyone....
  1. ABS & Brake lite on pump not running 93T&C
    By Buffalobilly in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 02-27-2009, 05:09 PM
  2. Surges When Stopping
    By bbartholomew1 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-29-2008, 01:57 PM
  3. intermittent brake and check engine light
    By tempfixit in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 03-02-2008, 04:52 AM
  4. Shuddering/Vibration when stopping
    By 06GC in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-24-2006, 09:54 PM
