2000 Voyager 4cyl timing belt replcement help
Results 1 to 6 of 6
Thread: 2000 Voyager 4cyl timing belt replcement help
    Mar 2008
    6
    My 2000 voyager (4cyl) timing belt is severely loose & about to go.....104K miles on van. Is there a link or step-by step directions that somone may have to show me how to remove/ replace belt,tensioner kit & water pump & re-time belt ????
    Never replaced a timing belt before....hope I'm not going to be sorry attempting this!!
    Any help greatly appreciated...
    Jan 2007
    1,292
    215
    From what I've read, the hardest part is getting pulley off crank shaft. Definetely need a good 3 jaw puller. I have a FSM you can borrow.
    Mar 2008
    6
    Quote Originally Posted by Sunvanse View Post
    Do you live in N.Y.?
    Jan 2007
    1,292
    215
    Mar 2008
    6
    Holy crap....its You!!! thx Grumpy
    Jan 2007
    1,292
    215
    For those searching how to instructions for 2.4 timing belt replacement, these are good pictures. The 2.4 Chrysler engine is not interferrence. (the 2.4 used in sebrings and stratus COUPES ARE interferrence Mitsu engines) I like the emphasis on proper harmonic balancer removal and re-install using a insert to pull and bolt/washer/nut to press back on. Not mentioned, but a must is to change the water pump, and probably the tensioners for timing and serpentine belts should closely checked and replaced also.
    http://www.howstuffinmycarworks.com/...t_Caravan.html
  1. 2002 Chrysler Voyager, 2.4, timing belt change interval?
    By Biff Malibu in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-17-2011, 07:31 AM
  2. 2000 Grand Voyager - Slipping belt in rain recall?
    By 2KGV in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-14-2011, 12:03 AM
  3. 2000 Grand Voyager - Slipping belt in rain recall?
    Last Post: 01-28-2010, 08:32 PM
  4. Timing Belt or Chain? 2000 Dodge Caravan SE Sport
    By rrf in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-22-2007, 12:15 PM
  5. Replies: 1
    Last Post: 07-03-2004, 07:45 PM
