Instrument cluster nighttime bulbs
Results 1 to 10 of 15
Thread: Instrument cluster nighttime bulbs
    Sep 2004
    Edmond, OK
    22
    Does anyone know how to go about replacing a night time instrument cluster backgroud light bulb? I see in the owners manual the light bulb number it calls for but no instructions as to how to replace it.
    2002 Chrysler Town & Country eL 3.3L V6 Flex Fuel 115K Miles
    2009 Mazda5 2.3L DOHC 28K Miles
    Jul 2003
    High Ridge, Missouri
    4,806
    I hope this helps. It is from the 2002 Service Manual. It would be easier to read if you print this out. Good Luck
    First- Remove Inst. Cluster:
    REMOVAL
    WITH ELECTRONIC TRANSMISSION RANGE
    INDICATOR
    (1) Disconnect and isolate the battery negative
    cable.
    (2) Remove Over Steering Column Bezel by lifting
    it straight up with a firm pull.
    (3) Remove the four cluster bezel attaching screws.
    (4) Tilt the steering column in the full down posi-tion.
    (5) Pull rearward on the cluster bezel and remove.
    (6) Remove the four screws holding instrument
    cluster to instrument panel.
    (7) Rotate top of cluster outward.
    (8) Disconnect the cluster harness connector.
    (9) Remove instrument cluster from instrument
    panel.
    WITH MECHANICAL TRANSMISSION RANGE
    INDICATOR
    cable.
    (2) Remove the lower steering column cover. Refer
    to Body, Instrument Panel, Lower Steering Column
    Cover, Removal.
    (3) Remove the plastic knee blocker reinforcement.
    Refer to Body, Instrument Panel, Knee Blocker Rein-forcement,
    Removal.
    (4) Disconnect the transmission range indicator
    cable end from shift lever by flexing the HOOP on
    the transmission shift cable rearward and slip the
    indicator cable loop off the lever pin.
    (5) Disconnect the clip holding the indicator cable
    to the mounting bracket.
    (6) Remove Over Steering Column Bezel by lifting
    (7) Remove the four bezel attaching screws.
    (8) Tilt the steering column in the full down posi-tion.
    (9) Pull rearward on the cluster bezel and remove.
    (10) Remove the four cluster attaching screws.
    (11) Rotate top of the cluster rearward.
    (12) Disconnect the cluster harness connector.
    (13) Remove the instrument cluster carefully while
    guiding the range indicator cable and guide tube
    through the opening to avoid any damage.
    To Change Bulbs:
    CLUSTER ILLUMINATION
    LAMPS
    REMOVAL
    (1) Remove the Instrument Cluster. Refer to Elec-trical,
    Instrument Cluster, Removal.
    (2) Turn over cluster and expose the illumination
    bulb sockets.
    (3) Identify which bulb is defective and twist it out
    of the cluster using a counterclockwise motion.
    INSTALLATION
    (1) Install the new bulb socket into the cluster
    using a clockwise motion.
    (2) Install the Instrument Cluster. Refer to Electri-cal,
    Instrument Cluster, Installation.
    (2) Using a flat bladed tool, pry off the lamp lens.
    (3) Remove bulb from lamp.
    To Reinstall the cluster:
    INSTALLATION
    INDICATOR
    (1) Connect the instrument cluster wire connector.
    (2) Rotate top of cluster inward as placing into
    instrument panel opening.
    (3) Install the four screws holding instrument clus-ter
    (4) Position cluster bezel into place.
    (5) Install the four bezel attaching screws.
    (6) Install the Over Steering Column Bezel by
    firmly snapping into place.
    (7) Connect the battery negative cable.
    INDICATOR
    (1) Guide the range indicator cable and guide tube
    through the opening of instrument panel.
    (2) Connect the instrument cluster wire connector.
    (3) Rotate top of cluster inward as placing into
    (4) Install the four screws holding instrument clus-ter
    (5) Position cluster bezel into place.
    (6) Install the four bezel attaching screws.
    (7) Install the Over Steering Column Bezel by
    (8) Connect the clip holding the indicator cable to
    (9) Connect the transmission range indicator cable
    end to the shift lever by flexing the HOOP on the
    transmission shift cable forward and slip the indica-tor
    cable loop on the lever pin.
    (10) Install the plastic knee blocker reinforcement.
    Installation.
    (11) Install the lower steering column cover. Refer
    Cover, Installation.
    (12) Connect the battery negative cable.
    Avatar: EconoVoyager Concept
    Sep 2004
    Edmond, OK
    22
    Thank you so much for that shop manual info!!
    The operation was a big success. It is a very easy job to do once you get the "Over SteeringColumn Bezel" off. It unsnaps from the front edge and rocks upward. It took quite a bit of force to bust it loose.
    I didn't have to unplug the wiring harness. There was enough slack to get to the bulb sockets on the rear of the cluster. I figured it would be better to leave it alone if I didn't really need to unplug it.
    THANKS AGAIN!!
  5. #4
    Jul 2003
    4,806
    Glad the info helped. I definitely agree with you on this:
  6. #5
    Nov 2003
    South Hills of Pittsburgh, PA
    1,313
    I tend to replace ALL the bulbs at the same time when I have to go in there.
    I actually have been quite lucky. The only car I remember having the dash lights go out on was my 77 Ford Granada (first one.)
    The lights were always so dim that I had them all the way up.
    In my Satty, I keep them down so low that you can only see them in total darkness. I really HATE bright dash lights. That may be why mine have lasted so long because they are never all the way up.
    Even my high beam indicator is annoyingly bright. I am not happy with where it is on the Caravan. Directly in my line of sight.
    Chas
    Chas Stokes
    2000 Saturn SL1 "ZUUL"
    2002 Hyundai Elantra (Stolen ) "ZUUL24"
  7. #6
    Mar 2004
    Toronto
    214
    Quote Originally Posted by BigDaddy
    THANKS AGAIN!!
    You didn't happen to notice the type of bulb used? I want to change mine from green to blue LED if possible.
    2001 Grand Caravan Sport AWD 3.8L V6
  8. #7
    Jul 2003
    4,806
    I agree on replacing all the bulbs as long as you are in there. I also keep my brightness level 'LOW' when driving. I have never had a bulb go out on me, YET.
  9. #8
    Sep 2004
    Edmond, OK
    22
    Quote Originally Posted by ZUUL24
    Yes I agree that would be the best approach.
    Quote Originally Posted by BABYGRAND
    The owners manual said PC74 which comes with a new base socket. I used a 74 bulb which has no socket. I was able to pry the blown bulb out of it's socket (it was soldered in) and replace it with a plain 74 bulb. The only reason I tried this was that I had a 74 left over from replacing a cup holder illumination bulb in my Saturn.
    The color of both the factory and my replacement bulb are clear. The green color apparently comes from the instrument cluster. I'm not sure what you could do to make it blue.
  10. #9
    Jul 2003
    4,806
    BABYGRAND, You may have problems doing that. In the OLD DAYS they used to put a cover (rubber,slipped over the bulb) to do the green color of the dash. Now , I believe that the bulb pops into the hole and a green plastic shield is around the bulb,part of the panel. You may have alot of trouble trying to change the color of the instrument panel lights.
    Good Luck
  11. #10
    Mar 2004
    Toronto
    214
    Quote Originally Posted by DSMLVR
    Good Luck
    Thanks, I do recall those coloured caps that they use to have, you may be right the guage faces themselves may already have the green film otherwise they would look white with the lights off.
  1. instrument cluster lights
    By Dannyda in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-09-2013, 09:57 PM
  2. Replacing instrument panel bulbs
    By Fred Spanuello in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-09-2009, 10:01 PM
  3. 2001 T&C instrument cluster
    By 2001TC in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 09-05-2007, 08:03 PM
  4. instrument cluster replacement
    By irod1459 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-17-2005, 06:36 PM
  • You may not post replies
