Power Steering Pump Removal
Results 1 to 10 of 13
Thread: Power Steering Pump Removal
    Nov 2006
    Venice, FL
    311
    1
    Has someone posted pictures of what they did to replace the pump on a 3.8L?
    Seems like the best way is from the top, correct?
    1996 Town & Country, Original owners, 3.8L 95,000 miles.
    Nov 2006
    Venice, FL
    311
    1
    Also someone said the CAN on the back of the pump can be replaced w/o removing anything more than the lines, correct. I have pin hole leaks in that CAN pump works fine.
    Jul 2005
    NJ
    1,562
    5
    That can needs to be checked every time you change oil. Mine had a rust spot.
  5. #4
    Jun 2009
    St. Cloud, MN
    1,345
    Country: Users Country Flag
    63
    I left the pulley on it and got it out through the bottom. Have fun!
    DAN(husband of member STEPHANIE)
    2000 Chrysler Town & Country Limited - Dark Charcoal Metallic with chrome trim, taupe leather interior, loaded. In need of rust repair on rockers and liftgate. Now enjoying the new family mommy-mobile!
    Knowledge can never be wisdom without experience.
    "Your experience is a commodity."
    "Opportunity is not a lengthy visitor."
    DRIVE = LOVE
  6. #5
    Nov 2006
    Venice, FL
    311
    1
    Pump arrives tomorrow, I will take some pictures of whichever way I decide to go.
  7. #6
    Jan 2010
    Canada
    141
    12
    Unbolt the pulley from the crankshaft and I believe it comes out the bottom.
  8. #7
    Apr 2009
    2
    Hello everyone.
    Thanks to this forum I was able to do this job in less than a day. On my 00' 3.8 T&C, I pulled the pump out thru the passenger wheel well in this manner:
    1. Block and Jack the vehicle
    2. Remove all plastic shrouding in wheel well.
    3. Remove serpentine belt
    4. Remove 3x15mm bolts holding the pump to the bracket using an offset box end wrench.
    5. Slide under to the backside of the pump. (bring every extension and 15mm thing you own, and the droplight)
    a. Remove L shaped bracket holding PS pump to block. (1x15mm nut & 1x15mm bolt)
    b. Remove serpentine belt tensioner. (1x15mm nut).
    c. Hang a 15mm box end wrench on the nut for the bottom alternator bolt.
    6. Slide back to the wheel well side and:
    a. Remove 3x15mm bolts on lower PS bracket
    b. Remove 1x15mm bolt, head facing the firewall.
    c. Remove 1xlong 15mm bolon lower alternator (this is the one you hung the box end wrench on).
    7. Wiggle the PS bracket free, and remove via wheel well.
    8. Place Bucket under Pump area.
    9. Remove Hoses from Pump.
    10. Remove Pump via the wheel well.
  9. #8
    Apr 2009
    2
    Well, clicking the "insert image" do-dad didn't work.
    I'll put 'er into a gmail album, and give that a whirl . .
    Does this work for anyone?
    http://picasaweb.google.com/VCityKarl/AutoRepair#
  10. #9
    Nov 2006
    Venice, FL
    311
    1
    Yes That works.
  11. #10
    Nov 2006
    Venice, FL
    311
    1
    Here are a few pictures of the install on a 96 T & C. I removed the whole Alt/PS Pump bracket from the top.
    This is the bracket once out of the van. The bracket is combo of a stamping and a casting.
    Tensioner is in the middle minus the pulley.
    View from wheelwell with old pump still in place.
    Sorry photobucket quit on me.
  1. hello- power steering pump 3.8L
    By barca_texas in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-17-2010, 12:16 PM
  2. Power Steering Pump Removal 2000 Voyager with 2.4 Liter
    By Plymouht2000 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-28-2010, 10:24 AM
  3. Power steering pump gone bad.
    By daveman591 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-24-2010, 03:00 AM
  4. 3.3 Litre Power Steering Pump - Removal
    By Renegade1127 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-05-2008, 05:04 PM
  • You may not post replies
