What is a TCM quick learn?
Results 1 to 6 of 6
Thread: What is a TCM quick learn?
    Mar 2010
    16
    I have a 02 limited T&C with 121,678. Tranny jerks 50% of the time if i have the RPMs below 2000. It happens only when it shifts to second. 3rd shifts great and down shifting no problems. It feels like a jerk jerk jerk when it shift to 2nd gear. If i push the RPM's high when starting from a stop it will shift fine. I changed the tranny fluid and found no metal shavings on the bottom pan. I am asking if a TCM quick learn will correct the timing issue on shifting pattern, or am i screwed into paying the dealership to diagnose the issue i am having. Any advice would be helpful. Thanks...
    2002 Limited Town and County, 2005 Touring Pacifica,
    Use to own 2005 PT Cruiser
    Apr 2009
    Empire State
    3,814
    quick learn should improve the shifting for a while.. it seems fairly common to have harsh shifts after ATF & filter change, but if the seals are starting to leak or solenoids are sticking quick learn may not be much help in the longer run..
    I've put a bottle of slick50 into 3rd gen tranny at about same mileage and it significantly improved shift quality... (figured I'd try it first)
    Quote Originally Posted by FSM
    STANDARD PROCEDURE - QUICK LEARN
    PROCEDURE
    The quick learn procedure requires the use of the
    DRBIIIt scan tool. This program allows the PCM to
    recalibrate itself. This will provide the best possible
    transaxle operation.
    NOTE: The quick learn procedure should be per-
    formed if any of the following procedures are per-
    formed:
    Transaxle Assembly Replacement
    Powertrain Control Module Replacement
    Solenoid/Pressure Switch Assembly Replacement
    Clutch Plate and/or Seal Replacement
    Valve Body Replacement or Recondition
    To perform the Quick Learn Procedure, the follow-
    ing conditions must be met:
    The brakes must be applied
    The engine speed must be above 500 rpm
    The throttle angle (TPS) must be less than 3
    degrees
    The shift lever position must stay until
    prompted to shift to overdrive
    The shift lever position must stay in overdrive
    after the Shift to Overdrive prompt until the
    DRBIIIt indicates the procedure is complete
    The calculated oil temperature must be above
    60 and below 200
    relevant vehicle: '05 -=C=- T&C Ltd @~130K
    Jan 2010
    winterville, GA
    221
    When's the last time you changed the fluid and put +4 in it? If it's been more than 30K you're overdue.
    '87 Caravan LE 3.0, '91, '92, '93, '94 Grand Caravan LE 3.3
    '02 T&C Limited 3.8, '09 T&C Limited 4.0
    Mar 2010
    16
    We purchased the van 2 years ago and the previous owners did a flush on it. The van sat in the back of the dealership with a dead battery for 6 months as they forgot they had it for a trade in. I ran into the old owners and asked them if they had problems and they said no. I though it was the wrong fluid so i changed it but no help. I was thinking about trying trick slick. I don't know if its even worth taking it into the dealership to have it diagnose since its quit expensive. Last question... What is a Re-flash on the tcm? Thanks for the reply's... Much appreciated....
    Apr 2009
    Empire State
    3,814
    TCM re-flash is software (to be technically correct "firmware") update..
    BTW, these vans (gasoline versions) do not have a separate TCM - everything is packed into NGC (next generation controller) PCM+TCM..
    If ATF flush was done by a dealer it should have had ATF+4 in it.. if not, one service ATF change only replaces less than half the fluid... (you should change the fluid 2 more times at least 100 miles apart.. or flush with correct fluid, no need to change the filter again if the one you took out was in decent shape and not too much residue in the pan...)
    41TE (these trans) are notorious for rejecting generic fluid..
    Edit: harsh 1-2 shift below 2K RPM seems to be a "standard" feature on these.. (my van does it on occasion - happens most often warmed up in bumper to bumper traffic..)
    Oh wait, Welcome to the forums!
    Mar 2010
    16
    Hey thanks for the welcome. I love my T&C, It bugs the crap out of me if something is not working right. I will try exchanging the fluid once more. Its great i found this forum as everyone hear has been helpful. Thanks again...
  1. Quick Struts aint so quick!
    By 98t&c in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-15-2012, 05:40 PM
  2. TCM Quick Learn - Necessary?
    By chengny in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-31-2010, 01:35 PM
  3. tranny solenoid "quick learn"
    By codgerdog in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-23-2009, 01:09 AM
  4. Quick way to kill a van.
    By Police Interceptor in forum 1st Generation Chrysler Minivan: 1984-1990
    Last Post: 03-07-2004, 05:15 PM
  5. Auto transmissions...Self Learn??
    By Alex in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-09-2004, 07:48 AM
