Hard first to second gear shift - what to check
Results 1 to 10 of 19
Thread: Hard first to second gear shift - what to check
    Apr 2008
    36
    My 1998 Caravan Sport has started to shift hard from first to second after it's warmed up, but only under light load. If I give it a little gas and let it shift around 3500 - 4000 rpm, it shifts fine. I've changed the fluid every 30k miles since I bought it new. Could it just be a worn clutch? These 41TE/A604 trannies have a solenoid pack. Can that wear out? I'm trying to keep this thing alive for a few more years so my teenagers have something to drive.
    It has the 3.3 liter engine (flex fuel), 201,000 miles and everything works.
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by robk46 View Post
    The solenoid packs are known to wear and cause shifting issues. If the trans is original to the van, I would say it is a safe bet to replace the pack for $100.
    The problem I foresee is teenagers driving the van. Any boys in that group? I just turned 20 and have been driving my van since I was 15. It is a good vehicle to learn on, but if one beats on it (like guys are known to do) it will go to crap very quickly. My van is in poor shape mostly because of me.
    '69 GTO drop top
    Nov 2008
    DeSoto County, MS
    2,926
    My van did the same thing. A rough shift into second.(and also 4th). I took my chances and replaced the solenoid pack. It shifts smoothly through all the gears now. I can't promise you that it will help yours, but like andy said, with that many miles it wouldn't hurt, and it helped mine.
    Apr 2008
    36
    The trans is original. My son has been driving it since he wrecked his car. He doesn't beat on it since he knows it's the only wheels he has until he fixes his car. He works at an auto parts store, so we may just give the solenoid pack a try (20% discount). Is it hard to replace? If I remember right, it's right there when you pull the pan. . .
    Nov 2008
    DeSoto County, MS
    2,926
    The valve body is what is under the pan when you pull it. The solenoid pack is on the front of the transmission. It's the big black square on the front.
    Here is a thread I started when I changed mine. Lots of info and pics on it:
    http://forum.chryslerminivan.net/showthread.php?t=14810
    It's very simple to change. 3 bolts and remove the input speed sensor (i think) as it's in the way. Be sure to spray around the solenoid pack with a water hose or something to clean the dirt from around it so it doesn't get into the transmission when you remove the solenoid. When you remove the old one there will be a seperator plate between the solenoid and transmission. Be sure it comes off. Mine was stuck to the transmission and I hardly noticed it. You won't need it with the new on.
    The new pack will have 3 studs that will seem to be in the way but once you get the 3 bolts threaded and started they will push into the solenoid pack as you tighten them. It will come with a new gasket as well and you will not need to reuse the rubber cover that is on it. The plug on the top has a bolt in it that will need to be removed to unplug it from the pack.
    Apr 2008
    36
    Wow, that looks easy. Much better than working on my 200r4 or th350.
    Apr 2008
    36
    I think mine might be just worn clutches, since it only does it when the fluid is warm. I'm going to go to the salvage yard tomorrow and get one off a recently wrecked '06 caravan. Looks pretty easy to swap. . .
    Dec 2006
    1,113
    31
    Just an FYI that sometime around '98 or '99 they switched from a pin-style to a spade-style electrical connector on the solenoid pack. If the new one you get has a different style connector, you've got a wiring job ahead of you
    - G
    1998 Grand Voyager @336,000mi, 3.3L FFV V6
    Nov 2008
    DeSoto County, MS
    2,926
    That would make since if I had paid attention as the fluid is thicker when it's cold but once it warms it thins and reveals the worn clutches.
    As for the solenoid pack plug. I believe the plugs are all the same on all A604/41TE's no matter what the year. A 2007 solenoid pack will be interchangeable with a 1997.
    Apr 2008
    36
    I changed the fluid an filter about 10k miles ago when I replaced the front tranny mount, so I don;t think it's the fluid. Won't hurt to do it again though. . .I'm guessing the solenoid pack regulates fluid pressure, so if mine has 200+ thousand miles on it, it could be borderline bad. I'm sure I can get one cheap, so why not try it? I may just buy the whole tranny out of the '06 if they're interchangeable. Then I have a spare when the original finally gives up.
  1. Hard shift under acceleration...
    By SHOBrad in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 03-07-2016, 08:37 PM
  2. wont shift out of first gear?!?
    By Justin in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-05-2013, 08:14 AM
  3. hard 1-2 shift...new owner
    By wirzy79 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-24-2012, 10:45 PM
  4. Hard shift into first gear
    By 97voyager in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-21-2010, 09:31 PM
  5. Whining with A/C + gear shift...
    By Jon7289 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-19-2009, 08:53 AM
