Light knocking noise from engine P and N ?
Results 1 to 10 of 14
Thread: Light knocking noise from engine P and N ?
    Feb 2010
    3
    Hi to you all,
    I am Michel from Holland and i own my first Chrysler Voyager 3.3 V6 build in 2004. A great car !
    There is one thing were i am worry about.
    My engine has a light knocking noise by normal engine-temperature when it's running about 800 RMP waiting in traffic, or whe i put the gear in natural or parking.
    I read some things about the timing chain and tensioner.
    Do i need to repair the tensioner ?
    Does anyone has a drawing or drawings of the 3.3 V6 engine ?
    Thanks from Holland
    Jul 2008
    Niles Il.
    10,101
    Is it a knock or a light ticking?
    Ticking is quite common from the 3.3/3.8's and is not a huge deal unless it starts to get worse over time.
    How many miles, or kms?
    '69 GTO drop top
    Feb 2010
    3
    Andy, It's more a light knocking noise from the top of the engine. It's not symmetric.
    The engine has run about 170.000 km.
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    If it's the "known lifter noise", a can of SeaFoam into the oil will usually remedy that, however, If it's a lower sounding noise, you may have a rocker problem and want to have a mechanic look at it.
    When you do your next oil change, get the larger filter, similar to the MotorCraft FL1 in size and quality (yes, even though it's a FORD filter, it fits perfectly and is superb on the Chrysler).
    Still Going Strong
    May 2006
    New Hampshire
    8,395
    Quote Originally Posted by Michel from Holland View Post
    Completely normal for the 3.3 and 3.8 liter engines. FWIW, I first heard the light knock in the engine in our 1998 DGC back when it had 50,000 km on it, by the time I traded the van in with 275,000 km on the clock the knocking was still there, no better or no worse, and the engine ran as well as it did the day I drove it off the showroom floor.
    2006 Acura TL 6-Speed
    Oct 2008
    2,469
    43
    You say it is not symmetric, I understand that to mean erratic, not regular. If it is a clatter, "klik,...klikkity, klack,.. klick" at irregular times, and it is coming from the belt side of the engine, I would suspect you are describing the noise that comes from the timing chain slapping on the guide, which can get more noticeable with age. My 90 3.3 did it for it's entire life and never was a problem for 15 yrs. A knock, as you are saying, is usually used to describe valve ping or clatter on acceleration or a connecting rod knock, and it usually most noticeable when you let up on acceleration, when load is off the pistons and they are more free to knock around. Hope this helps.
    By the way, you did not say if this started suddenly or has been there all along, could make a difference in diagnosing the problem. Anything that starts suddenly is always of more concern.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Jan 2005
    Fayetteville, NC
    9,436
    Neither of our 3.3 or 3.8 engines have had a "knocking" noise. The 3.8L was louder on certain brands of oil, with more valvetrain noise. On Pennzoil Platinum 5W-20, it's absolutely quiet as a mouse.
    If it's a louder knocking noise, it may be a cracked flexplate. We've seen that happen before on these engines as well.
    May 2006
    New Hampshire
    8,395
    Quote Originally Posted by Jason View Post
    As far as I know, the random knocking is a "problem" only for the Gen 3 and prior vans. Our 2003 with 135,000 miles on it has no such noise, so apparently Chrysler "fixed" this problem with the Gen 4 engine update.
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by shipo View Post
    True. My engine makes a slight knock at times that I consider normal and fine as it has been doing it for as long as I can remember.
    Sometimes to does make a deeper knock that is not too comforting, but it could be anything and does not concern me.
    '69 GTO drop top
    Mar 2009
    80
    Quote Originally Posted by AzTraveller View Post
    I know this is slightly off the original topic, but how long is the FL1? I run an oversize filter (8A -which is a Ford V8 filter) on my '01 Dodge Intrepid R/T which has the same OEM filter as the 05 T&C. but the oil filter sits much lower on the 3.8L engine in the T&C, practically at the bottom of the engine. I've been hesitant to put a longer filter on there for fear of road debris hitting the bottom.
    -Dan
    2005 T&C Touring
  1. Sliding doors knocking noise
    By sat22 in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 02-28-2011, 02:27 PM
  2. 2004 Town and Country Rack Knocking Noise
    By 2ez24get in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-18-2010, 07:15 PM
  3. 96 Chrysler T&C Knocking noise rod/bearing/torgue plate?
    By kshortjr in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-04-2008, 06:10 PM
  4. Knocking noise in front end 97 Grand Voyager
    By hardrock2 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-03-2006, 09:49 AM
