Water Pump and Timing Belt Replacement
Results 1 to 8 of 8
Thread: Water Pump and Timing Belt Replacement
    Feb 2010
    2
    Could someone please be that kind and write me a step by step direction how to replace a water pump and the timing belt on my 2001 Dodge Grand Caravan, 6V, 3.8 engine. Thank you very much. Michaela
    Jul 2008
    Niles Il.
    10,101
    Water pump is easily accessible through the passenger wheel well.
    The 3.3/3.8 engines use a timing chain which is good for the life of the engine. No replacement necessary.
    '69 GTO drop top
    Oct 2008
    2,469
    43
    I don't know if your model requires it, but some have noted that loosening, not removing, the bolts on the passenger side motor mount will give enough clearance to get the pump out. (It lowers the engine a skosh.) You can find full directions on removal at the Autozone.com website, register and look at the repair instructions.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    May 2004
    Ames, Iowa
    1,415
    8
    I would recommend taking it to the shop for the waterpump. There have been a few guys who do their own work on here, that have had to button it back up and take it to a shop for completion. It depends on how die hard you are.
    It was 15 degrees F here when mine needed replacement, so Chrysler got it. I may have tried it on my own otherwise.
    IAFarmer
    Current Rides
    02 Chrysler Voyager
    2012 Volkswagon Routan
    2016 Ford F-150 FX4 4x4
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Cool
    Hey, IA, I hear IOWA got a Norwegian Ice Breaker to open up the river up there last month ......
    http://abitquirky.blogspot.com/2009/...-heads-up.html
    Still Going Strong
    May 2004
    Ames, Iowa
    1,415
    8
    Quote Originally Posted by AzTraveller View Post
    Got me on that one!!!
    IAFarmer
    Current Rides
    02 Chrysler Voyager
    Nov 2008
    DeSoto County, MS
    2,926
    x2 what andy said (as always ) The water pump isn't a maintenance item on the 3.8 like it is with the 3.0 timing belt. The 3.8 has a timing chain that doesn't need to be replaced on a schedule like a timing belt. The water pump is easily accesable from the bottom (if the 4th gen's are the same) and only needs to be replaced if it's bad.
    Oct 2008
    3,508
    Talking
    Quote Originally Posted by misacvackova View Post
    Welcome to the Forum
    As was mentioned, pending where you're located, it may be much easier to have the dealer do it, it is very tight quarters where the pump is on the engine. The 3.8L is basically the same block as the 3.3L, but longer stroke and larger bore. The chain is well designed to last the life of the engine.
    Are you having leakage at the pump, or are you just curious how to do it? Pending your year van, the HAYNES manual covers much of your maintenance and is about $30 at Autozone or PepBoys.
    If you wish to share your location we can assist in recommendations much better.
    Still Going Strong
  1. I'll be replacing my water pump and timing belt now :(
    By JebusKrist in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 06-11-2010, 04:56 PM
  2. How many miles should I replace Water Pump + Timing Belt
    By montreal in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-24-2009, 04:46 PM
  3. HELP!!! In the middle of timing belt/water pump replacement...What a nightmare!!!
    By g3_ultra in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-01-2009, 08:59 AM
