Oil Light Keeps Coming On
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Oil Light Keeps Coming On
    Aug 2008
    105
    I filled it with Mobil 1 synthetic oil about 1000 miles ago. The light has been coming on intermittently the past couple of weeks. I checked it it wasn't all that low, but I added more. Light still keeps coming on once in a while. Today it came on at start, drove it for an hour. Started it back up and the light was gone. WTF? I know the oil level is fine, what can be triggering it?
    2005 Chrysler Town and Country Touring 3.8L
    My DIY Contributions:
    Lower Radiator Tube Replacement
    http://forum.chryslerminivan.net/showthread.php?t=14636
    Leaking Steering Rack - Added lucas oil in winter of 2010-11 no leaks since then, but replaced PS Reservoir (9/2012 no leaks)
    EGR Valve - FIXED 5/27/11
    Front Brake Pad/ Rotors replaced 93k
    Rear Rotors: 95k
    Last Oil Change:90k
    spark plugs: 95k
    Needs Fixing-
    Windshield, rear brakes, tranny flush, , oil pan is rusted bad!
    Jan 2009
    Ohio
    595
    Quote Originally Posted by markho View Post
    You may have a bad oil pressure sender. There easy to change, its right above the oil filter, in front of the oil filter housing.
    01 Dodge Grand Caravan (Sport) 3.3
    New tranny at 99,650 miles
    Currently 123,000 miles
    Aug 2008
    105
    Quote Originally Posted by Kscha41 View Post
    Thanks. I found this thread too:
    http://forum.chryslerminivan.net/sho...ight=oil+light
    Whats the actual part name? Napa lists it as a Oil Pressure Light Switch, I think.
    http://www.napaonline.com/Search/Det...50016+2016026#
    Rear Rotors: 95k
    Last Oil Change:90k
    spark plugs: 95k
    Needs Fixing-
    Oct 2008
    2,469
    43
    If you went to a much lighter oil, a 0 or 5w whereas you were using heavier before, it could have caused the problem. I say that since you mention it happened after the change. But the sensor will also go bad, mine did, it would sporadically, sometimes yes other times no, just show the pressure dropping while I was driving. Sending unit ended the problem. It is by the filter or on the other side of the engine from the filter, usually.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Jan 2008
    Nova Scotia, Canada
    16,494
    Likely cause is the sensor or the wiring/connection to the sensor.
    If your engine was sludged up some, the synthetic oil (if this was a first time use) could have dislodged a lot of stuff to be caught by your filter. What filter are you using?
    Here's how the system works. http://www.filtercouncil.org/techdata/tsbs/83-1R2.pdf The pressure sensor is beyond the filter. Might consider changing the filter.
    Aug 2008
    105
    Quote Originally Posted by Jeepman View Post
    If your engine was sluged up some the synthetic oil (if this was a first time use) could have dislodged a lot of stuff to be caught by your filter. What filter are you using?
    It was a MOPAR filter.
    Rear Rotors: 95k
    Last Oil Change:90k
    spark plugs: 95k
    Needs Fixing-
    Oct 2003
    Niagara Ontario
    825
    I would replace the pressure sensor. It is located right above the oil filter. I believe it only cost me between 10 and 20 canadian dollars at the dealership. Replacing it solved my oil light problem. Read your trouble codes, mine set one I forget the code though.
    Hank
    07 Dodge Caravan SXT 3.3L Gold 135,000 kms
    05 Dodge Caravan SE 3.3L Silver 200,000 kms now sold and replaced with a 13 Journey.
    84, 89, 93, 94, 95 Chrysler minivans in my past, all served me well and are long gone.
    90 Shadow long gone
    Oct 2008
    2,469
    43
    If you want to be sure, for free, you can likely borrow (pay for and bring back for refund) an oil pressure gauge at Autozone or other parts house. Remove your unit, put it in and run the engine to see what the pressure it. One caution, some of these units are an aluminum housing and wring off in the hole if you overtighten. The last ones I did are a taper fit pipe fitting so they gradually get less thread and tighten on themselves. Not sure on the Chrysler. Did that on my Simca. You can rent a sending unit removal socket at the same store. Might as well buy the unit too, and return it if it is not needed. Hankster and Jeepman have good points. If your new super oil broke loose or dissolved a lot of goop, it could be clogging the oil filter, but if so, do your lifters clatter when the light comes on? If not it may well be the unit (Unless the lifters are now full of junk too).
    2000 Caravan 2.4l
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by tcwagner1 View Post
    The lower number doesn't matter. What matters is the higher number. You can use any oil that has a hot viscosity of 30. Now straight SAE30w will drastically reduce fuel economy when cold, but will be no different when hot.
    But yes, the sensor is probably the issue. I've seen one go bad instantly once. I was under the car with the engine running and it had no leaks but suddenly oil came blowing out of it. Although this was on a GM 3.4 engine and those were pretty terrible all around. Seems to happen often on any type of vehicle.
    '69 GTO drop top
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    I have had to replace my sending unit on a couple of vehicles. Yes, they can cause the problem you are describing. Yes, they are easy to replace. Also consider getting one of the "big filters", not the little ones. The big ones provide better overall flow, as well as more filtering surface. Just make sure they have the anti-flow back valve in them. SEARCH this forum for "oil filter" and you'll find the recommended models.
    Get back to us with your results.
    Still Going Strong
  1. Coming soon, to Texas.....ME and my 09 DGC
    By yakdude01 in forum The Fireplace
    Last Post: 08-19-2010, 10:30 PM
  2. check engine light keep coming on
    By butkun in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-05-2010, 10:01 AM
  3. Change Oil Light Coming On At 2900 Miles???
    By RossInILL in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 12-05-2008, 12:39 AM
  4. So when ARE the new models coming?
    By Hokiefyd in forum The Fireplace
    Last Post: 10-10-2005, 05:56 PM
  5. Diesel coming??
    By DSMLVR in forum The Fireplace
    Last Post: 09-16-2005, 04:49 PM
