Interchangable Parts from My Chrysler Sebring LX?
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 74
Thread: Interchangable Parts from My Chrysler Sebring LX?
    Jun 2009
    On the world wide web
    715
    I posted a while ago that I was recently Given a 2001 Chrysler sebring LX, It has a rod knock and its gonna be a second Project for 2009. If I change my mind and want to junk it, it has a the 2.7L engine in it, with a A-606 42LE transmission in it.. Will that transmission fit my caravan?..My Gram has a 2001 Chrysler 300M and if anything Ill save the transmision for her car, she only has 41,000 miles on her 300m but you never know..
    Jul 2008
    Niles Il.
    10,101
    from what I read, the 42le is turned 90* to make it front drive with a traditional rwd engine layout. I don't think the trans would be much use to you unless you wanted to make your engine longitudinally mounted for some reason in the future. I would get a used 2.7 engine for cheap and replace it. I know they have sludging issues, but it is not too hard to take the new engine apart and clean it up.
    '69 GTO drop top
    Jan 2005
    Fayetteville, NC
    9,436
    I don't think it has a 42LE transmission. In Chrysler nomenclature, L = Longitudinal (as in north-south, or typical RWD fashion), and T = Transverse (as in sideways, like our vans are).
    4 = number of speeds
    2 = relative strength of transmission (1 = lowest, up through 6 and 8 sometimes)
    L = longitudinal
    E = electronic controlled
    Our vans use a 41TE, or a relatively weak 4-speed transverse electronic unit. My Dakota has a 44LE, a modestly strong 4-speed longitudinal electronic unit.
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by Jason View Post
    L = longitudinal
    True. If it does happen to be a 42te or 41, you could use it in the van. It will make acceleration better due to transfer and drive ratio changes for the smaller engine as well. Depends on if you like gas mileage or go power.
    '69 GTO drop top
    Jul 2009
    Tunkhannock, PA
    430
    L = longitudinal
    Lets not forget the 41AE for those of us blessed with AWD
    2005 Kia Sorento LX 4x4 44,000mi
    2003 Chrysler T&C Limited 3.8l AWD 145,000mi Traded in 9/14/11
    2000 Dodge Stratus ES v6 179,000 sold 7/2011
    Jan 2005
    Fayetteville, NC
    9,436
    Quote Originally Posted by aKids2003_DGC View Post
    Reading this closer, I'm not sure it'll work in the 300M either. The 300M's engine does sit longitudinally, but it's still FWD. The Sebring, as far as I recall, uses a standard transverse layout. In other words, I don't think that Sebring's transmission would be any good for anything other than a Sebring. I'm sure it wouldn't even directly bolt into one of our vans; the mounting points are likely different, etc.
    My question is more about the engine; is the rod knock a sure thing? How bad is it? What has been done to try to remedy it (if anything)?
    Nov 2008
    DeSoto County, MS
    2,926
    The transmissions you mentioned...the 42LE, is a 41TE with a different diff and output. It was used in the LH platform. You know, the crazy setup on the LHS, Concorde,Intrepid,300M, etc. with the engine longitudinal yet it's still FWD. Though it was also used with the 2.7 in the intrepids(longitudinal mount) it wasn't used in the sebrings. The sebring has the 41TE with both the 2.4 and the 2.7 engines. So that transmission would fit in your van, if the mounts are the same...which they probably are, if anything the internals would. As for anything else, scrap it. Not much you can use for it for your van or the 300m save for maybe an alternator or something if it fits. The 2.7 is based on the 3.5 which is based on the 3.3. The 2.7 however is known for sludge issue's which is probably what caused the rod knock, from lack of oil circulation. It's probably toast. If you took a valve cover off, it'd more than likely be coated in peanut butter, depending on the mileage.
    Jul 2008
    Niles Il.
    10,101
    Myself, I would pull the oil pan, replace the rod bearings and clean out the sludge by hand then run many oil flushes through the engine. Unless it was a headgasket or something that failed.
    '69 GTO drop top
    Nov 2008
    DeSoto County, MS
    2,926
    Well, with the early 2.7's, like the one in this sebring, that would only be a band-aid. The oil passages were to narrow and it caused slow circulation, cooking the oil, there was also PCV system issues and timing chain issues. There were just a lot of design flaws in the head. The bottom end is tough, it's the same as the 3.5, the heads are different though...their attempt at DOHC didn't turn out so well. They supposedly fixed it, though I've read a few complaints of 2.7 failures in the 300's as well (LX platform)
    Nov 2007
    347
    15
    Quote Originally Posted by sideburns2009 View Post
    I think the use of synthetic oil and frequent oil changes will significantly aid in engine life with the 2.7. One of the issues is the water pump is internal and when it leaks, it gums up the oil.
    2004 Chrysler Town and Country 3.3, 292,000 miles
  1. My Chrysler Sebring fill in..1990 Beretta GT
    By aKids2003_DGC in forum Chrysler Mid-Sized & Compact Cars
    Last Post: 05-13-2010, 12:59 AM
  2. OEM Chrysler Parts on-line
    By skidad in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-04-2009, 03:18 PM
  3. Chrysler repainting parts of my van
    By PCE Scott in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-18-2009, 11:19 PM
  4. Mirror Glass Interchangable
    By freebie-1 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-19-2008, 09:31 PM
  5. Chrysler Parts
    By tysons4 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-02-2007, 09:56 PM
