Leaking Steering Rack? Two spots under front end
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 36
Thread: Leaking Steering Rack? Two spots under front end
  1. #11
    Oct 2008
    2,469
    43
    The easiest way to tighten the hose is from below with a crowfoot wrench and a nice extension in it, I think it is 15 mm, but it has to be a rather slim profile to fit. You can go to the Autozone website and register and look under repair info and it will give you pictures and everything. Someone here can give you the size of the crowfoot, best if a flare for the fitting, but a regular one will do in a pinch. Be very careful starting the new hose, if removed, so you don't strip it, and don't use teflon tape on it, can cause overtightening. It has an o ring to seal it.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
  3. #12
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by Jeepman View Post
    Maybe this is what you are thinking of:
    Cold temperature leaks can occur as well and may be as simple to fix as tightening up the hose clamps.
    Yeah I knew it was something like that. I didn't remember exactly because I don't dabble in the 4th gens too much.
    '69 GTO drop top
  4. #13
    Oct 2003
    Niagara Ontario
    822
    The steering racks on 2005's seem to have a problem with leaking at the ends of the rack. Even at low mileage. Something was changed for 2005 and later. My rack leaks out the ends duiring cold weather as well, im hoping that a recall or extended warranty will be done to it.
    Hank
    07 Dodge Caravan SXT 3.3L Gold 135,000 kms
    05 Dodge Caravan SE 3.3L Silver 200,000 kms now sold and replaced with a 13 Journey.
    84, 89, 93, 94, 95 Chrysler minivans in my past, all served me well and are long gone.
    90 Shadow long gone
  5. #14
    Aug 2008
    105
    well i took a quick look under the van this morning before the wife took it, and oil is slowly dripping from the end of each boot, both driver's and passenger side. I couldn't get under the van completely to check the hoses, yet but i will later.
    So what can I do to fix this? Replace the bands on the boot?
    2005 Chrysler Town and Country Touring 3.8L
    My DIY Contributions:
    Lower Radiator Tube Replacement
    http://forum.chryslerminivan.net/showthread.php?t=14636
    Leaking Steering Rack - Added lucas oil in winter of 2010-11 no leaks since then, but replaced PS Reservoir (9/2012 no leaks)
    EGR Valve - FIXED 5/27/11
    Front Brake Pad/ Rotors replaced 93k
    Rear Rotors: 95k
    Last Oil Change:90k
    spark plugs: 95k
    Needs Fixing-
    Windshield, rear brakes, tranny flush, , oil pan is rusted bad!
  6. #15
    Aug 2008
    105
    okay I checked again with the van jacked and supported. The steering gear's (Haynes refers to this as a steering gear, is this the rack?) Anyway, boots on both ends of it are leaking. How do I fix this?
    Rear Rotors: 95k
    Last Oil Change:90k
    spark plugs: 95k
    Needs Fixing-
  7. #16
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by markho View Post
    Yes that is the rack. When they leak, the whole rack needs to be replaced.
    The boots aren't supposed to have any oil in them. They are only there to keep road dirt and stuff off the polished piston coming out of the rack. When they start to get oil, it means that seals internal in the rack are bad,
    '69 GTO drop top
  8. #17
    Aug 2008
    105
    awesome
    I don't have the money or time to get this fixed, could I try a Lucas product to slow the leak down?
    Also, is this a dealer part? Or can I get a better aftermaket part since this is obviously a piece of crap design, which should not have crapped out on me at 69,000 miles
    Rear Rotors: 95k
    Last Oil Change:90k
    spark plugs: 95k
    Needs Fixing-
  9. #18
    Jan 2009
    Ohio
    595
    awesome
    I tried the Lucas stuff in mine and it stopped it for two weeks or so and then it came back but worse. I bought a reman rack from napa with a lifetime warranty but I think they are all still the same crap design. The rack was a pain ot put in, but we save a lot of money.
    01 Dodge Grand Caravan (Sport) 3.3
    New tranny at 99,650 miles
    Currently 123,000 miles
  10. #19
    Jul 2008
    Niles Il.
    10,101
    I would give the lucas power steering fix a shot. If it helps for awhile then you can spend that time saving up knowing the repair will need to be made sooner or later.
    '69 GTO drop top
  11. #20
    Aug 2008
    105
    Quote Originally Posted by Kscha41 View Post
    i read your posts involving this procedure and I think you said its something you wouldn't do again. If I get quoted under 1000 do you think its worth it? I would do it, but it looks like a major PIA...
    Rear Rotors: 95k
    Last Oil Change:90k
    spark plugs: 95k
    Needs Fixing-
  1. Just Replaced Steering Rack Steering Linkage Boot is now not Sealed Glue it?????
    By Eager in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 08-15-2010, 02:19 PM
  2. Leaking Steering Rack
    By Hankster in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-11-2010, 10:05 PM
  3. Failed Safety Inspection leaking power steering rack
    By 4_cars in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-25-2009, 08:46 PM
  4. 3.3L V6 Steering Rack - HELP !
    By Renegade1127 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-02-2008, 08:33 PM
  5. Leaking steering rack
    By My_van_dont_work in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-16-2008, 08:53 AM
