GC 2009- Bad key??
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: GC 2009- Bad key??
  1. #11
    Jun 2009
    Jefferson City, TN
    3,051
    Quote Originally Posted by lxman View Post
    The part you put your key in is the ignition switch and also is the wireless control module, WCM.
    I don't think so. The wireless control module is in the column. But I'll ask at work tomorrow to make sure...
    And yes, it does control the anti-theft, remote fob functions, and on some vehicles it is what reads the tire pressure monitors.
    And what is WCM?
    Jeff
    Current:
    Previous minivans:
  3. #12
    Dec 2008
    225
    3
    Quote Originally Posted by jgbat View Post
    And what is WCM?
    I think WCM stands for wireless control module.
    If the WCM controls these functions, then there is a good chance its responsible for our key and fob problems!
    Current: 2012 Mazda 5, 2012 Mazda3 SkyActiv
    Previous: 2011 Grand Caravan, 2009 Grand Caravan SE, 2002 Grand Caravan Sport and several other Chrysler vehicles
  4. #13
    Jun 2009
    Jefferson City, TN
    3,051
    Quote Originally Posted by JOEMAMA View Post
    Duh! I'd say WCM does stand for wireless control module. We just never call it that at work, we always say wireless control module. LOL!!
    And it does control all those functions. So yes, it very well could be your problem.
    Jeff
    Current:
    Previous minivans:
  6. #14
    Jun 2009
    Jefferson City, TN
    3,051
    I stand corrected, the thing you put the fobic (new fob key thing) is part of the wireless control module as well. lxman was correct. I was wrong.
    But again it does control all those functions, and more in some vehicles.
    Jeff
    Current:
    Previous minivans:
  7. #15
    Jun 2010
    2
    Same problem here..."Bad Key" message intermittently...sometimes for a long time
    5 days before the problem started, I had a 2nd key programmed by a locksmith…no problem.
    The day before the problem, I programmed a 3rd key myself using the instructions in the operator’s manual…no problem.
    The day the problem happened, I was walking to the car in a parking lot, and I hit the panic button to find my car. The horn beeped 3 times and I turned off the panic switch. I got to the car…had my 3 keys in my pocket…I opened the locking glove box and put one of the keys in there. I locked the glove box, and then tried starting the van. The message “Bad Key” flashed as I put it in the vehicle. It would not start…appeared to be dead, but the key fob was able to unlock doors and open the automatic side and rear doors.
    I tried all 3 keys and the same thing happened. Would not start. I fiddled with things for a bit, and eventually the car started. I shut down the engine, removed the key and tried starting it again. Bad key message and then dead. Still all three key fobs unlocked the doors and opened the doors and hatch with no problem. Eventually after fiddling, it started the van again…can’t figure out what in the fiddling was the cause of freeing up the problem.
    Got to my next destination. Same problem. “Bad Key” message and had to fiddle with things before I could get them to work properly.
  8. #16
    Jun 2010
    2
    Batmobile...did you ever get this resolved? I have the same issue. See my post on page 2.
  9. #17
    May 2010
    5
    I had something very similar... but found a quick and dirty solution.
    Mine started the same thing... usually you could open the door but not start the car... or vice versa you couldnt open the door but when the door was opened manually you could then happily start the car.
    Whilst waiting for replacement parts for the car I stumbled apon a temporary cure... change the location of the steering wheel!...
    I found that when one of the two scenarios above would strike, if I used the tilt adjuster on the steering wheel to drop it down slightly everything worked.
    When they went to swap out the WCM they found that some people at the factory had run the antenna cable from the WCM up through the steering wheel assembly and that when I had the steering wheel above a certain level (I am tall so I have it one click from the top) the antennae cable would get 'shorted' against the hinging mechanism in the steering wheel.
  10. #18
    Sep 2014
    1
    I heard that the key is designed to allow only certain number of ignitions then it stops working. That may be the problem.
  11. #19
    Jun 2004
    rochester,ny
    748
    7
    Quote Originally Posted by sideburns2009 View Post
    Bah! Too many electronics!
    Truer words have never been said. Go back to conventional keys and ignition switches . I'll take my chances with someone breaking in and trying to start the car.
    2014 Dodge Grand Caravan AVP
    Deep Cherry Red
    45000 miles
    2008 Isuzu Ascender
    Midnight Metallic
    105500 miles
  1. 2009 3.3 Gas Mileage
    By tek4u in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 02-15-2010, 03:57 PM
  2. 2009 GC Key Fob Problems
    By JOEMAMA in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 09-12-2009, 11:56 PM
  3. 2009 Summer Over
    By ikemando in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-30-2009, 07:08 PM
  4. 2009 T&C Issues?
    By smeach in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 03-07-2009, 08:13 PM
  5. T & C or G.C SXT 2009 3.8
    By Baveux in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 10-06-2008, 08:13 AM
