Remove high pressure steering hose/ 99 TC. HELP
Results 1 to 6 of 6
Thread: Remove high pressure steering hose/ 99 TC. HELP
    Jan 2010
    4
    Help Please. I have 99 T/C minivan. 3.8 motor, 2wd. I tried to replace the high pressure hose that runs from the Power steering pump to the ....rack? The end at the pump was a piece of cake. I wasn't so successful at the other end. I can't seem to get any wrench's up where the hose goes through the nut. What's the secret? Please help. Thanks,
    Jul 2008
    Niles Il.
    10,101
    I replaced my rack and had to do the same job. I don't remember exactly what I did, but I know I had to cut down the wrench so I could get it in there to use. It was a big pain as the lines were TIGHT.
    Good luck.
    '69 GTO drop top
    Oct 2008
    2,469
    43
    I did the same on my 90 GC. I ground down (made thinner), I believe it was a 15mm wrench to get it in there. I just looked on the Autozone repair manual for this and it shows a crowfoot wrench on the end of a long extension, to get at this flare nut without lowering the crossmember. It looks like a flare nut crowfoot, but I don't know where you would find it unless Napa has one, I know you can buy a set at Harbor Freight for not too much.
    Say, does anyone know if you can cut the ferrule off and reattach the hose using a couple of gas line hose clamps on the high pressure side? I did this on an old Coronet 440 I had and it worked great, but I don't know if the pressures on these racks are too high to do it. That may be all you need to do, if you can't get the other end off the rack.
    Welcome SandRWeimer
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Jan 2010
    4
    Thanks for the info. Sounds like the crowfoot wrench is the way to go. Many thanks
    Jan 2010
    4
    I Used a Crowfoot wrench. It worked great. The hardest part was getting the threads to start on the new line, on the side away from the pump. It was very tight. The whole job took about 2.5 hours.
    Oct 2008
    2,469
    43
    So did the leak stop? Hope all is well.
    2000 Caravan 2.4l
  1. high pressure ac hose valve
    By pippo in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 07-11-2010, 09:12 PM
  2. Power steering return hose
    By dgtc in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-29-2010, 08:38 PM
  3. 200 TC power steering hose
    By woodhog in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-21-2008, 11:38 PM
  4. Power steering hose went again!!!
    By toubis in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-24-2007, 07:42 AM
  5. Remove 2003 power steering reservoir
    By KCMike in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-11-2007, 04:35 PM
