Airbag sensor in front bumper
Results 1 to 8 of 8
Thread: Airbag sensor in front bumper
    Jan 2010
    4
    I was wondering if anybody could help me locate the air bag sensor in the front bumper. I own a T&C 2006 touring minivan. tnx . Also the web site where i can order one
    Jul 2008
    Niles Il.
    10,101
    Shouldn't there be 1 per frame rail mounted behind the actual metal bumper? I'm not sure exactly as I've never had my van that far apart in the front.
    Also, the sensor may be a dealer only item.
    '69 GTO drop top
    Jan 2010
    4
    I had my T&C checked by a technician regarding the airbags. the warning light for the airbags keeps popping up. Technicians told me the front sensors has to be replaced. Anyway thanks so much.
    Dec 2008
    Illinois
    20
    I have a 06 and I put in a center consule right after I got the van and right after that the air bag light in the dash came on. Since I had warranty I took it back to the dealer they checked it and found out the connection on the seat belt on the passenger side was loose. I guess it also has somthing to do with the airbag light so in messing around the seats puting the center counsul in I must have pulled that switch loose he just connected it back up and its been fine ever since
    Apr 2009
    New Jersey
    179
    2
    Some vans had a recall on them for the airbag sensors. You might want to see if yours is one of them.
    Harold in New Jersey
    2005 Dodge Grand Caravan SE 3.3
    Apr 2009
    Empire State
    3,874
    from service manual:
    IMPACT SENSOR
    DESCRIPTION
    FRONT IMPACT SENSORS
    There are two front impact sensors (Fig. 21), one
    on the left, and one on the right front sides of the
    vehicle. These sensors are mounted remotely from
    the impact sensor that is internal to the Occupant
    Restraint Controller (ORC). The right and left front
    and side impact sensors are identical in construction
    and calibration and each front impact sensor is
    secured with two screws. The front impact sensors
    are secured with two screws to the outboard sides of
    the right and left front rail tips.
    The impact sensor housing has an integral connec-
    tor and two mounting ears, each with a metal sleeve
    to provide crush protection. A cavity in the center of
    the molded black plastic impact sensor housing con-
    tains the electronic circuitry of the sensor which
    includes an electronic communication chip and an
    electronic impact sensor. Potting material fills the
    cavity to seal and protect the internal electronic cir-
    cuitry and components. The front impact sensors are
    each connected to the vehicle electrical system
    through the headlamp to dash wire harness.
    The front impact sensors cannot be repaired or
    adjusted and, if damaged or faulty, they must be
    replaced. If a front impact sensor is faulty, only the
    sensor needs to be replaced. If the sensor is damaged
    or faulty, or if proper tightening torque of the screws
    that secure the sensor to the bracket cannot be
    achieved, the sensor and bracket must be replaced.
    Refer to the proper body diagnostic information for
    diagnosis and testing.
    Fig. 21 FRONT IMPACT SENSOR
    REMOVAL
    FRONT IMPACT SENSOR
    The right and left front impact sensors are
    mounted identically on the front rail tips.
    (1) Open hood, disconnect and isolate the battery
    negative cable.
    (2)
    WARNING: Wait two minutes for the airbag system
    reserve capacitor to discharge before beginning
    any airbag system or component service. Failure to
    do so may result in accidental airbag deployment,
    personal injury or death.
    (3) Hoist vehicle.
    (4) Disconnect electrical connector (Fig. 24).
    (5) Remove the two screws attaching front impact
    sensor to outer rails (Fig. 24).
    INSTALLATION
    FRONT IMPACT SENSOR
    (1) Position sensor in vehicle (Fig. 24).
    (2) Install the two retaining screws to the impact
    sensor (Fig. 24). Torque screws to 7 Nm (62 in. lbs.).
    (3) Connect electrical connector (Fig. 24).
    (4) Lower vehicle from hoist.
    WARNING: Do not connect the battery negative
    cable (Refer to 8 - ELECTRICAL/RESTRAINTS -
    DIAGNOSIS AND TESTING - AIRBAG SYSTEM). Per-
    sonal injury or death may result if the system test
    is not performed first.
    (5) Verify vehicle and system operation.
    (6) Close hood.
    Jan 2010
    4
    Thanks for the info. I'll try to check it out when i get home.
    Apr 2009
    Empire State
    3,874
    Keep it safe, be real careful with airbags and accelerometers...
  1. Front bumper 2005 T&C
    By 3timer in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-12-2010, 08:25 AM
  2. Changing the front bumper?
    By anotherred in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-27-2010, 07:54 AM
  3. front bumper exchange
    By joshockey in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-10-2009, 08:20 PM
  4. how to replace front bumper on 2003 minivan
    By ml8203 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-06-2009, 01:43 PM
