I just found an application chart on line for the "Help" self bleeding brake caliper screws. It is product #13901 and the pitch is 3/8 -24. It is 1 1/4" long. Has a ball check valve inside, once loosened, will let fluid out, not let air in. That is the theory anyway. About 6 dollars, which if you are married, is a lot cheaper and less tempermental than a wife being yelled had to "Pump it, Hold, and Let it Up" for a half hour. Someone mentioned that his did not work well, but Advance will refund your money if they don't.
Application chart: http://www.dormanproducts.com/cgi-bi...tegory_list=:0
