Steering wheel wobbles and pulls to the left
Results 1 to 10 of 14
Thread: Steering wheel wobbles and pulls to the left
    Jan 2010
    27
    My problem is with the 94 town & country minivan now at reg drive speed i get a real bad wobble in the steering wheel and if your just coasting at 1 MPH with it out of gear you can fill the steering wheel start to pull to the left after the tire makes a complete rotation the steering wheel go's back to alinement then when the wheel starts a new rotation it starts to pull again. Driving at 45 mph it is hard to hold onto the steering wheel with this problem. Any help please would be great
    Mar 2007
    2,949
    Axle shaft/CV joint - is my suspicion.
    -Jim
    Jun 2009
    Vancouver BC
    259
    Bad tire?
    88 Lincoln Mark VII - My Hot Rod
    96 Voyager RIP June 09 Written Off because of a scratch on the fender, sigh....
    01 Caravan 3.3 SWB SE, 125k Km the new family hauler
    94 SWB Caravan Sports Edition - Wifes 165K Km
    Jan 2010
    27
    could a broken coil spring on the strut cause this problem with the wobble...
    Oct 2008
    2,469
    43
    I would get it to a front end shop pronto to get it analyzed. You can go in for one of those xx point free inspections at a tire shop and they will probably find it. But this is too dangerous, it could fall apart at high speed. This is if you are not able to jack up the wheel and wigglie it and find out what it is yourself. Could be fatal, really.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Jan 2010
    27
    i had the wheel off today and spot checked the tierod it was tight balljoint was tight no wiggle in the wheelbearing the boots are all good no slop in any parts only broken coil spring on the strut but the steering wheel pull is just strange ive done work on my cars for 30 years and never had this problem before
    Oct 2008
    2,469
    43
    Carefully spin the wheel with your hand on the tread. Do you feel a bulge or irregular place? You could be having a separation of tread the is like a bubble under the tread. If your tires are more than 6 yrs. old, they are dangerous, but I have had them separate in 3.8 years. Could a rim be bent or broken?
    Another possibility is a badly warped rotor, when you hit the warp, it brakes that side slightly pulling it to the Left. Rotate wheel up and see if you have a point of resistance to rotation.
    2000 Caravan 2.4l
    Jan 2010
    27
    i dont think its separation of tread on the tire but now the rotor maybe being warped is a thought now if coasting at 1 MPR would a warped rotor cause the steering wheel to slowly pull the left then straighten back out then start over again this is something i will check out tomarrow it is something didnt think about checking thank you...
    Oct 2008
    Arizona, USA, and Elsewhere
    3,508
    Lightbulb
    This is definitely symptoms of a tire problem. Take it to your friendly tire shop (preferably where you bought the tires -- are they under warranty -- do you have road hazard on them?). Have them put it up on a lift and rotate them to see if they've been damaged in any way.
    Still Going Strong
    Jan 2010
    27
    if its a tire problem then if i rotate the back tire to the front 1 that is pulling it should stop pulling then or lighten up some would that be right
  1. Switching steering wheels for radio steering wheel controls?
    By jj200282 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-14-2009, 08:30 PM
  2. Rusted left wheel well seam and rocker
    By REINIER in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-26-2009, 01:45 PM
  3. Creaks in left front wheel of '07 T&C
    By BaaBaa17 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-10-2008, 06:40 PM
  4. Van pulls to left, alignment is "perfect"
    By mdbauer1962 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-17-2008, 04:05 PM
