2002 Wiring Diagram
Results 1 to 10 of 11
Thread: 2002 Wiring Diagram
    Dec 2008
    Montgery County, PA
    45
    2002 Wiring Diagram
    The radios, wipers, climate control module intermittently turn off in my 2002 T&C 3.8L. After cleaning the battery terminals, the problem went away for a period of time. Upon returning, I removed the battery tray and noticed the wiring harness underneath had a wire exposed due to rubbing against the tray. The Haynes Manual does not have specific wiring diagrams. Does anyone know what the Blue with Yellow stripe wire controls? Or where I could locate the diagram?
    Thanks in advance
    Jan 2008
    Nova Scotia, Canada
    16,359
    Sources for wiring diagrams/other valuable information:
    Library Information - General:
    Your local Library subscribes to various data bases of information, some of those may be related to automobiles. Typically, using your Library card # and a Library password, you can access this information at home. It may be worthwhile checking with your local Library to see what they have available and how to access it from your home computer. For example, a local library nearest to me has access to the Chilton Library with data for maintenance, repair, and bulletins/recalls. I accessd it recently for info related to topics on this Forum. I recommend Chilton for its format, video clips and numerous pictures.
    Library Information - ARRC:
    Public access to this has been changed. If your library has access to EBSCOhost Databases, then go to the Auto Repair Reference Center (ARRC), and submit your vehicle model year and take it from there. Try this site. If they ask for a number use 23456789 and if they provide a drop down list of libraries, use the one with Hamilton in it. Should work, but maybe not on weekends.
    Note: If info isn't there for your year / model, try another year or similar model.
    I just looked at the wiring dagram for the 2002 GC 3.8L on the ARRC site. There were no wiring diagrams given for the 2002 T&C.
    There is a Dark Blue/Yellow Tracer for the A/C Compressor Clutch Relay in the Integrated Power Module (fuse/relay black box - the Integrated Power Module (IPM), located in the engine compartment of your 2002 Chrysler/Dodge Minivan, houses the fuses and relays that help regulate your vehicle's electrical system) to the A/C Compressor Clutch.
    Was yours light or dark blue?
    Dec 2008
    Montgery County, PA
    45
    A wiring schematic shows a dark blue / yellow wiring going to the “Auto Shut Down Relay” in the PCM. What exactly does the “Auto Shut Down Relay” do? I don’t see how this would affect wipers, radio and climate control module.
    Dec 2008
    Montgery County, PA
    45
    Jeepman - I also looked at teh ARRC library and no diagrams were available. In a Haynes Manual, I found a schematic for a "typical engine control system" which shows dark blue / yellow and it goes to "auto shut down relay". The schematic shows a dark blue / black for the A/C Compressor Clutch. Am I mis-reading the schematic?
    Jan 2008
    Nova Scotia, Canada
    16,359
    Quote Originally Posted by PAL View Post
    Auto shutdown relay function: http://www.allpar.com/fix/codes/sens...-shutdown.html
    There are various blue wires with yellow tracers. Any near the battery could easily be coming from the integrated power module box which is near the battery.
    Sometimes circuits feed off of other circuits, so you would have to check to see if that might be happening in your case. For example, on my Jeep, the dash lights are on a circuit with a 10 amp fuse which comes off the park light circuit which is fused at 20 amps. So if my park light circuit fuse blows, out go my dash lights even though their 10 amp fuse doesn't blow.
    Jan 2008
    Nova Scotia, Canada
    16,359
    Take a look at the 2002 3.8L Grand Caravan wiring schematics. They would be the same. I was just looking at them on th ARRC site.
    Dec 2008
    Montgery County, PA
    45
    Jeepman - Thanks for the reference to the Grand Caravan schematics. It makes sense why the intermittent outage occurred when the climate control was on. Assuming the wipers, radio and climate control are tied together, fixing the exposed wire cured the problem....time will tell. Is it possible from the schematics to determine if these components are tied together?
    Jun 2009
    Vancouver BC
    259
    Try this thread, it seem to be a common problem. If you follow the links lots of info. Mine did it one day. After reading the link, I pulled my starter solenoid and everything worked again. Turned the power module upside down to look at the wires and it has never acted up again. 2 or 3 month now, I don't trust the thing now, I know it will act up at a bad time.
    http://forum.chryslerminivan.net/showthread.php?t=14569
    88 Lincoln Mark VII - My Hot Rod
    96 Voyager RIP June 09 Written Off because of a scratch on the fender, sigh....
    01 Caravan 3.3 SWB SE, 125k Km the new family hauler
    94 SWB Caravan Sports Edition - Wifes 165K Km
    Jan 2008
    Nova Scotia, Canada
    16,359
    With a quick look, the only thing I see common is the "Accessories Relay", so maybe something was happening through that when the blue/yellow wire was acting up. Might want to check other wires in the area of the blue/yellow one though in case there are corrision / arc paths there.
    Hope the fix works for the long term. Sounds good.
    Dec 2008
    Montgery County, PA
    45
    Just wanted to share....Since repairing the wire, the problem has not reoccurred.
    Thank you for everyone's assistances.
  1. Wiring Diagram
    By Kevins in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 02-22-2010, 11:17 AM
  2. RKE help needed! with wiring diagram
    By voikku in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-11-2009, 07:29 PM
  3. wiring diagram
    By judaspriest1984 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 01-05-2009, 01:44 AM
  4. Anyone with a wiring diagram?
    By shipo in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-09-2007, 08:55 AM
  5. EVIC wiring diagram
    By maverickbluer1 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-26-2006, 10:00 AM
