Losing brake fluid somewhere
Results 1 to 10 of 14
Thread: Losing brake fluid somewhere
    Dec 2007
    Great Falls, MT
    19
    Noticed today the brake fluid reservoir was almost empty. Obviously i have a leak somewhere. What are the common culprits for these vans? Lines seem to be on good shape. The van has 4 wheel disc brakes.
    In addition, the double verification to do a search is retarded. Hopefully the moderator could change this.
    2012 T&C Ltd. 35,000 miles
    Jul 2008
    Niles Il.
    10,101
    Follow the lines everywhere they go around. They should be fine unless they have been damaged from road debris. Most likely a caliper is the culprit. Just remove each wheel and look for leakage around them. It will be dark stained and wet. I would say check the rears first as if a front was leaking you would normally experience greatly reduced braking power and pulling.
    '69 GTO drop top
    Oct 2008
    2,470
    43
    You may not have a leak if your current pads are old. As the pads wear, the level goes down. That is why you should not add fluid before you change the pads, it will gush out as you compress the pistons to get the new thick pads in. You should see a leak on the inside of the rim of your tire if you have a leak on one of the calipers. Usually there is a kind of streaking, sun ray design on the rim and tire from escaping fluid.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Jul 2008
    Cincinnati
    323
    In some cars with mystery brake fluid loss you also see leaking from the master cylinder into the brake booster. Look around the firewall for anything leaking as well, but I have not seen anyone on here with that problem.
    I agree with Wagner above about the brake fliud level correlation to the pad thickness but I always keep the fluid topped off (and change it every year or so) and just vacuum some out of the reservior before compressing the pistons when changing pads.
    2005 T&C Signature Series, 64,xxx miles
    Lots of rust, leaking steering rack, bad rear AC condenser coil, rusted (and replaced) rear brake line. Looking forward to the next failure/defect that this Chrysler will bring into our lives.
    Oct 2008
    2,470
    43
    Quote Originally Posted by PCE Scott View Post
    That is correct way to do it, but most novices don't think to suck it out prior to pushing in their pistons, unfortunately. Makes a real mess.
    2000 Caravan 2.4l
    Feb 2009
    Victoria BC Canada
    1,927
    Quote Originally Posted by tcwagner1 View Post
    That is why I loosen the bleed screw, so as not to put any back pressure on the master cylinder and making a mess up there. When done just top it off and I am good to go.
    Jun 2009
    Vancouver BC
    259
    If you have ABS, you should lightly crimp the flex hose, open the bleeder and collapse the piston. The last thing you want to do is force all the dirty brake fluid back into your ABS unit.
    88 Lincoln Mark VII - My Hot Rod
    96 Voyager RIP June 09 Written Off because of a scratch on the fender, sigh....
    01 Caravan 3.3 SWB SE, 125k Km the new family hauler
    94 SWB Caravan Sports Edition - Wifes 165K Km
    Jan 2008
    Nova Scotia, Canada
    16,679
    Quote Originally Posted by amrc0308 View Post
    When was it last checked?
    - pad wear will make the fluid go down as mentioned by tcwagner1.
    - banjo bolt not tight enough may let fluid leak out.
    - defective brake hose(s) could leak
    - defective brake lines (rusted out for example) will leak.
    - connections, hoses to lines, may be defective and leaking.
    - caliper seals may be leaking.
    - leaks around the master cylinder or ABS equipment.
    How thoroughly did you check the brake lines?
    Don't understand your problem with the search function. For me I just type in a word or two and press "go", simple as that.
    Oct 2008
    2,470
    43
    The next time I do mine, I intend to do it as described here, drain out as much from the master as possible, put some fresh fluid in and bleed out old through screw as you depress the piston, then bleed fresh fluid through till it comes out the cylinders. I am a bit afraid to squeeze the hoses though, any danger to doing that, like later inner separation and malfunctioning of that brake?
    2000 Caravan 2.4l
    Mar 2007
    2,968
    Crimping a brake hose sounds like a very bad/dangerous idea to me - especially on purpose.
    The worst/dirty brake fluid is right at/in the cylinders; bleed first, then push pistons back to accommodate new pads. Even if you don't bleed first, it's not enough fluid to make it all the back to the master or ABS - just bleed it all out until running clean.
    -Jim
  1. Brake Fluid Change
    By Rodger in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-11-2010, 08:31 AM
  2. Still losing radiator fluid slowly.
    By mistypotato in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 08-10-2009, 01:02 PM
  3. brake fluid capacity
    By delubi in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-03-2008, 02:13 PM
  4. Brake fluid level
    By Caravan_Sport in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-27-2006, 09:47 PM
