3.8L Thermostat replacement: How-to
Results 1 to 4 of 4
Thread: 3.8L Thermostat replacement: How-to
    Feb 2004
    South Bend, IN
    982
    28
    After putting a new water pump and lower radiator hose on my 98 T&C, I decided to replace the thermostat and upper radiator hose. Glad I did. The hose was nearly shot. Have 162, 720 miles on the original factory parts. This is about a one hour job.
    Along the way, I snapped some pictures.
    Here is a tutorial guide to doing the job if you are so inclined:
    http://www.flickr.com/photos/landar/...7622875853230/
    98 Town&Country LXI, 3.8L, 192k miles (sold)
    Nov 2006
    Venice, FL
    309
    1
    Thanks, nice pictures.
    1996 Town & Country, Original owners, 3.8L 95,000 miles.
    Jul 2005
    NJ
    1,571
    6
    FSM gives a 250 lb-in torque value for the housing bolts (which is just under 21 lb-ft).
    After I tightened to that specification, the housing cracked. Do not use that figure, it's likely an error.
    For a 3.0 engine, which uses the same basic design, the same manual gives 105 lb-in.
    Feb 2004
    South Bend, IN
    982
    28
    Quote Originally Posted by alvin View Post
    I do not have an FSM so I torqued mine to 13 lb-ft based on the size of the bolt. Seemed about right. If anyone knows the right amount for sure, let me know and I will add it to the tutorial.
  1. Thermostat
    By hypervish in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-06-2010, 10:13 AM
  2. Going to a 180 F thermostat
    By ultraman in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-04-2009, 10:21 PM
  3. Broken Thermostat
    By bowen in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-05-2007, 09:12 AM
  4. Thermostat cover
    By icatfishman in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-30-2005, 08:07 PM
  5. Thermostat woes!!
    By BABYGRAND in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-19-2005, 05:56 PM
