3.8L Water Pump replacement How-To
Results 1 to 10 of 16
Thread: 3.8L Water Pump replacement How-To
    Feb 2004
    South Bend, IN
    982
    28
    Well, it finally happened. At 162,720 miles on the clock, my water pump seized up. I HAD been planning to replace it sooner as a preemptive strike but never found the time. The pump gave a brief warning several days before self-destructing with sounds and groans coming from the passenger side of the engine bay. When it finally went, it threw the belt and I had no power steering and of course, no cooling. I limped her home. Fortunately, I was only a few miles away.
    Once inside the garage and after cool down, I got to work. Installed a new pump and lower hose from NAPA. I got out my digital camera and made a short "How-To" on the pump replacement although it is a fairly straightforward replacement. Just thought someone who had never replaced one before could have a confidence booster. With just basic tools, it only takes about an hour to do.
    Here is a link to the tutorial. Enjoy.
    http://www.flickr.com/photos/landar/...7622749575845/
    98 Town&Country LXI, 3.8L, 192k miles (sold)
    Dec 2007
    Virginia
    259
    Apparently I don't have permmission to see your photos....
    This is interesting to me since I'm thinking about a preemptive replacement of my water pump on my van with 214K miles before I drive it from Virginia to Chicago and back over the Christmas holidays.
    BTW, I know South Bend fairly well ... went to you-know-what school there, and lived in Granger during 1988-93. Waaaay too cold for me to handle these days....
    Dave
    • 2003 DGC SE 3.3L - 248K miles and still strong
    • 2003 Nissan Frontier 2.4L - 186K miles
    • 2005 Ford Focus - 158K miles
    • 2008 Honda Civic - 90K miles
    Feb 2004
    South Bend, IN
    982
    28
    Quote Originally Posted by DaveKG55 View Post
    Sorry Dave, must have had the permissions set to "private". Try it now.
    Wow, you're an ND grad? Yeah, not too much pride around here these days.
    I actually live in Granger, not SB. You probably would not recognize the place anymore.
    Feb 2004
    664
    Good job for sure.. Water pump is actually quite easy.. pop off the serpentine belt, jack it up, take off the inner plastic fender well on the passenger side ( a couple of christmas tree clips) then undo the hoses and then there are just a couple bolts to take out, is pops right out, the big main O-ring that seals it to the engine is kind of a PIA to get back and seated, I just used blue silicone gasket in place of it.. works fine.. total time about 30 minutes. First time, maybe one hour max..
    2006 DTS performance
    2005 Pacifica
    2001 SSEi Bonneville
    2001 RAM Conversion Van
    1997 Magna
    www.femint.com
    Nov 2006
    Venice, FL
    309
    1
    Again, nice job with the pictures.
    1996 Town & Country, Original owners, 3.8L 95,000 miles.
    Jun 2009
    4
    it is an easy job
    one of the easier pumps to replace.
    Oct 2003
    Mt. Sinai N.Y.
    268
    15
    thank you 98T&C for the photos, it makes the thought of replacing the pump for a do it yourself er a lot easier to understand.
    Dec 2009
    lansing
    13
    lucky you I tryed to replace my water pump at 175k and broke 3 bolts in the front cover. had it towed to a shop thay where able to drill out the bolts. Its now got 185k and runs strong drives great
    Apr 2009
    3
    Anybody know if the procedure is the same for a 2005 T&C 3.8L? I found another website that states that you have to remove one of the motor mounts to replace the water pump, and I am hesitant to do that. But that other website sounded more like a quote from a repair manual than someone with actual experience.
    Ken
    Feb 2004
    South Bend, IN
    982
    28
    Quote Originally Posted by kglade View Post
    Ken
    Ken... it is easy enough to tell by yourself. Just climb underneath with a good light and look up at the water pump. If it appears to be as in the tutorial (easily accessible) then you have your answer. There should also be a diagram in your engine compartment showing how to string the serpentine belt. You can pinpoint the water pump location from that diagram.
  1. Water Pump Replacement Video
    By averkam in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-16-2010, 12:47 PM
  2. Water Pump and Timing Belt Replacement
    By misacvackova in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-10-2010, 04:14 PM
  3. water pump replacement / need advice.
    By bulldog van in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-19-2009, 10:15 AM
  4. Water Pump Replacement?
    By mrekimf in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 06-25-2008, 07:46 PM
  5. Water Pump Replacement
    By Mojo117 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-03-2007, 07:47 AM
