transmission plan with drain plug avail?
Results 1 to 10 of 12
Thread: transmission plan with drain plug avail?
    Oct 2009
    Chattanooga, TN
    12
    I have a 2003 T&C with 3.3L V6.
    I would like to get a replacement transmission pan with built in drain plug as I don't want to use one of the after market drain kits if possible.
    I see tons of pans that stop at year 2002 but find pans for the 41TE transmission on other years of Chryslers such as PT Cruiser. If the description says something like:
    03 PT Cruiser Transmission Oil Pan 40AE 40TE 41AE 41TE
    would that pan fit?
    Jun 2009
    Jefferson City, TN
    3,051
    I think that pans are the same for a 2001 to a 2007... I know they take the same filter...
    And FWIW, the pan on my 1997 looked the exact same too...
    As far as the PT pan, well I have no idea. It may be different since it is a different application...
    Jeff
    Current:
    Previous minivans:
    Oct 2009
    Chattanooga, TN
    12
    I wonder how I can find out for sure? The only place to get one is online and would hate to try and deal with a return if it wasn't the same.
    For reference, all the transmission pans for any town and country come up with this description:
    http://www.1aauto.com/1A/Transmissio...er/TownCountry
    Other online retails use the same model years. I don't know if that's because there is only one company that makes this aftermarket pan and they are just using their same description.
    Jan 2007
    1,291
    215
    If your existing pan is not rusted out, I would just install a drain plug on it. I don't think you will find one with one installed already. This is because most people would just drain and re-fill, never dropping the pan to clean magnet and replace filter.
    Oct 2009
    Chattanooga, TN
    12
    Quote Originally Posted by Sunvanse View Post
    I really doubt that will keep someone from doing proper maintenance on their vehicle. That's like saying there's people who drain their oil but never replace their oil filter. I bet there are those who do that, but would Chrysler create a design that forced people to do something reasonable like replace their filter?
    As it is, a lot of people never service their transmission so I doubt a drain plug would make those same people start replacing the fluid.
    The people who would do something stupid like never replace the trans filter are the ones who pull up to Walmart and don't see an option to change the trans fluid so they think it must never have to be done.
    Jun 2009
    Jefferson City, TN
    3,051
    There is a pan with a plug avaliable from Chrysler. I'm not sure the part number, but I was told there is one.
    Jeff
    Current:
    Previous minivans:
    Oct 2008
    2,469
    43
    Go to Napa and ask the guy to crossreference the gasket. If the gasket is the same, the pan will fit.
    But to be honest with you, I think there are two better and easier options, depending on what you want to accomplish.
    1. If you just want the fluid out, Buy a 6 dollar fluid pump at the store and run the tube down the fill tube and suck it out without even going under the car. I have done it three times when I was switching out my fluid after I had the filter changed at the dealer. If you park on an incline you will get a gallon out, which is just about what you get by dropping the pan.
    2. Get the rubber gasket from NAPA for about 6 dollars and use it indefinitely. You can drop and retorque it many times, for years. Just snug it up, don't try to squeeze it in two. This will allow you to clean your magnet and check for any problems. You can change the filter too, if you like.
    But that is my opinion.
    2005 T&C Ltd 3.8 108,000
    2000 Caravan 2.4l
    1965 Ply Valiant V8 85k
    Oct 2009
    Chattanooga, TN
    12
    Quote Originally Posted by tcwagner1 View Post
    Excuse my ignorance I haven't done a lot of my own maintenance over the years. I am now doing it for cost savings more than anything.
    So you don't have to use any type of sealer when using this rubber gasket?
    The main reason I thought a drain plug would be good is instead of doing a full flush which would be expensive for ATF+4 fluid and for some reason no parts store or even Walmart has more than 3-4 qts in stock any given time. So I thought I'd drain it ever 10k miles or so and in effect get a full fluid replacement between filter changes. Plug dropping the pan is so messy it seems.
    I bought the van used and since I've had it I've neglected the trans. so I really want to get all the fluid out.
    Jan 2008
    Nova Scotia, Canada
    16,445
    Quote Originally Posted by rastoma View Post
    One of the simple $3.99 or $6.99 hand bulb siphon pumps shown here should work, or can be rigged up to work, if a smaller tube is needed down the dip stick tube. I have used the $3.99 type to empty my power steering reservoir which has ATF+4 in it. Works well. You can pump the gas out of your Neighbour's car with it as well, if times get too rough.
    The oil drain plug is fairly simple once one determines where the best installation point is. Here's one such kit using a washer seal similar to what is used on your oil drain plug (it has a washer to prevent leaks).
    If you get 50% old fluid out with first change, then you will have 50% remaining, next change will have 25% old fluid remaining, and so on, looking like this: 50%, 25%, 12.5%, 6.25%, 3.125%, 1.5625%. So, at the end of the run, you have less than 2% old fluid remaining after 6 drains/refills. 4 or 5 drains/refills should give you lots of comfort considering that the average transmission probably doesn't get that over its lifetime.
    May 2004
    Ames, Iowa
    1,415
    8
    I bought a universal plug to install on my pan. However, when it came time to drill the hole, I chickened out. The pump idea is a very good idea. I have used a pump when I overfilled the tranny.
    IAFarmer
    Current Rides
    02 Chrysler Voyager
    2012 Volkswagon Routan
    Ordered: 2015 Ford F-150 4x4
  1. Transmission Drain Plug Installation
    By Dodgeboy77 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 11-07-2010, 08:43 AM
  2. transmission pan with drain plug
    By Trophyslayer in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 04-13-2010, 07:36 PM
  3. Transmission Pan Cooler / Drain Plug
    By TobyD in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 05-19-2008, 06:17 PM
  4. Rad coolant drain and vent plug - doesn't drain
    By ebo2112 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-17-2007, 12:31 AM
