Code p1699 and pcm swap changed odometer
Results 1 to 9 of 9
Thread: Code p1699 and pcm swap changed odometer
    Feb 2008
    83
    Hello all,
    well it is one of those days when the van is acting crazy. I pulled codes and got p1699. I can't find anything on this code. any comments. even a search on several search engines did not turn up much info.
    also the control module that controls the AC, power doors and dash was replaced. the mileage on the odometer is now different.???
    Feb 2008
    83
    found this info on a website but do not understand what it is saying???
    http://www.engine-light-help.com/jee...ine-light.html
    Apr 2007
    San Diego
    5,264
    No bus data from climate control module means the PCI data bus isn't seeing any info from the climate control panel. All the modules (computers) in the van communicate over two wires called the PCI multiplex data bus. It acts just like the data bus on your home computer. The module in the climate control panel isn't communicating. Could be as simple as a loose connection on the panel. A common problem is overheated and melted connectors on the panel. Might try removing it and checking the connector.
    Your mileage is off because they just changed your BCM and neglected to reprogram the correct mileage figure into it. The BCM controls the mileage figure on your odometer.
    Why was the BCM?PCM? replaced? Can you expand on "acting crazy". What model year?
    Feb 2008
    83
    thanks for the info. I might need to have you explain or expand your answer after I post this info.
    van is 01 T&C limited. 140K 3.8L
    van was normal. all systems good. then after not driving for a few days the van was dead. checked battery and voltage was down. jumped the van and it ran fine. about a week later after not driving for a few days, same thing, dead battery. had the battery checked and it needed charging but was a good battery. had the alt checked and it is good. all of this did not throw any check engine lights.
    did the key "on / off" thing, it showed p1684 (battery) and also p1699 (?). mechanic came up with the problem being something in the pcm shorted and draining the battery.? replaced the pcm and the odometer mileage changed. have not had enough time since pcm change out to leave the van sitting and see if battery dies again.
    also I am not 100% on the use of the word "pcm". I was told this but maybe the real part is the "bcm", which I heard can change the odometer. sorry if the pcm and bcm are not accurte in my descriptions.
    also I have heard the expansion valve "hissing" when yopu turn the van off. it only hisses for a few seconds but I do not remember hearing it before.
    thanks
    Apr 2007
    San Diego
    5,264
    If everything on the climate control panel is working I wouldn't worry about the P1699 code. I'd have to bet he changed the BCM. Apparently it was creating what is called a "parasitic drain" on the battery just meaning something is on when it shouldn't be. The BCM normally draws around 30 milliamps of current when everything is off. Your mechanic must have seen something much higher.
    BCM = Body Control Module - It controls most of the electronics in the van located under the hood near the fuse panel.
    PCM = Powertrain Control Module - The engines brain located either outboard of the battery or behind the drivers side wheel well liner near the headlight
    Feb 2008
    83
    thank you for the information and education.
    the van seems almost back to normal. the bcm did come from a donor van and I guess that's why it now reads a different mileage. the ac is working but the driverside is a little warmer than the passenger and rear. even though all settings are set at 60 degrees. also the cd player buttons are all flashing. there are no cds in the slot but all 6 buttons are flashing.? we are still waiting to see if the van can sit for a few days and not have the battery go down.
    Feb 2008
    83
    well, here is an update. it looks like the van had a voltage spike or someone jumped the van and connected the battery cables backwards. I think this is why the bcm went bad and caused the parasitic drain , RIP, mentioned. I also think that the ac and cd issues are related to the same thing. I am going to try and reset the system (disconnect battery) and see what that does. I am also going to run the climate control calibration process. as for all the lights on the multi CD player flashing , I will let you know.
    Aug 2010
    1
    Quote Originally Posted by RIP View Post
    So my climate control is not working on our 01 chrysler t&c.. along with the outdoor temperature on the ceiling.. how can i fix that? our fans still blow but cant turn the actual power button or a/c on.
    Apr 2007
    San Diego
    5,264
    Quote Originally Posted by lxlmunch3rlxl View Post
    You could try pulling the IOD fuse in the fuse box. Leave it out for 2-3 minutes then reinstall. This will reset the BCM. That will effect the odometer, not sure on the HVAC panel. Remove the panel and inpect the connector. They can overheat and melt creating various problems.
  1. Speedometer and odometer off 10%
    By jbones in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-10-2009, 10:36 AM
  2. Engine Swap or Tranny Swap???
    By tempfixit in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 03-16-2009, 12:51 PM
  3. DTC Code derived from Odometer
    By ANQUETIL in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-29-2008, 06:30 AM
  4. P1699
    By bushrat in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-21-2007, 12:36 PM
  5. odometer
    By donk in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-14-2007, 02:35 PM
