How to replace reading light bulb?
Results 1 to 10 of 11
Thread: How to replace reading light bulb?
    Mar 2008
    Southern WI
    381
    4
    Does anyone know how to remove the little reading-lamp bulbs from the overhead console to replace them? I have one that sometimes goes dim.
    Pat
    08 T&C Touring
    Previous vans:
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
    Mar 2008
    Southern WI
    381
    4
    OK. So you pull/pry and the trim pops off. Now I really have a problem. There is a round flat led inside these that is about the size of the lense and held on by two posts. I didn't try squeezing the posts together to see if it would pop out (or if it's maybe soldered in).
    All the parts sites (including Wagner-the manufacturer) list a 194, which this surely isn't.
    Pat
    08 T&C Touring
    Previous vans:
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
    Mar 2008
    Southern WI
    381
    4
    As long as I've come this far here is a picture of the led and also the pcb side with the plastic posts clipped on.
    I'll try my dealer and some wrecking yards.
    Pat
    08 T&C Touring
    Previous vans:
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
    Dec 2008
    225
    3
    I wouldn't be surprised if you have to buy the entire assembly, as opposed to just a new LED. This is true for high mounted brake light, which consists of several LEDs.
    That being said, the LED shouldn't be failing so soon - they last in many cases 10,000+ hours. I bet there is something wrong with the circuitry.
    Current: 2012 Mazda 5, 2012 Mazda3 SkyActiv
    Previous: 2011 Grand Caravan, 2009 Grand Caravan SE, 2002 Grand Caravan Sport and several other Chrysler vehicles
    Mar 2008
    Southern WI
    381
    4
    Rather than just stay at a low level the light has taken to flashing high and low several times a second. I find it sort of festive when the first door is opened at night, but my wife...not so much.
    The Dealer will replace it under warranty. Those lights should outlast me.
    Pat
    08 T&C Touring
    Previous vans:
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by monza View Post
    Yep. LED's can go up to 100k hours which would probably never happen in a vehicle.
    '69 GTO drop top
    Apr 2008
    New England, USA
    1,659
    20
    I would recommend swapping the 'bad' lighting assembly with another one in the vehicle. It looks like you have two available to you in the pictures. Just change places and see what happens.
    If the blinking problem remains in the same assembly, then you know the problem is with that assembly. You almost certainly will need to replace the whole assembly. Replacing that LED is possible, but only if you get the right LED (good luck).
    If the problem starts occuring in the same location, but on the previously 'good' assembly, then you've got a connector or wire harness problem.
    2009 Dodge Grand Caravan SXT (3.8L), Light Sandstone Metallic, 125K miles
    2005 Volvo XC70, 160K miles
    Previous van: 2002 Chrysler T&C, eX (3.8L)
    Mar 2008
    Southern WI
    381
    4
    Quote Originally Posted by jgiurleo View Post
    Tried swapping and the unit is bad.
    Tried looking for just the LED. No way.
    The Dealer has a new unit to replace this one. I don't think they consider this to be a "wear item" like a lightbulb because of the extreme MTBF of the LEDs.
    Pat
    08 T&C Touring
    Previous vans:
    00 T&C 3.8
    95 GV 3.3
    89 Caravan 3.0
    Apr 2008
    New England, USA
    1,659
    20
    That, and the fact that it might not be the LED itself. There are a few other components on the PCB as well that could be failing.
    Mar 2014
    1
    Pat, I have a similar issue but not under warranty anymore. Did they replace the whole console or just the led? Thanks.
  1. Courtesy Light bulb 567...
    By k9sar in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-25-2014, 05:19 PM
  2. Rear Reading Light Bulb Replacement
    By Graham in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 06-08-2010, 05:17 PM
  3. Changing Map Light Bulb
    By lowbuckbob in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 02-13-2010, 07:46 AM
  4. speedo light bulb
    By GrandCaravan in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 09-12-2009, 07:05 PM
  5. How to Replace Turn Signal Indicator Bulb on 1998 Plymouth Grand Voyager SE 3.0 V6
    By ojames3 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-13-2009, 04:56 PM
