06 air pressure valve stems replace ?
Results 1 to 9 of 9
Thread: 06 air pressure valve stems replace ?
    Dec 2008
    Illinois
    20
    I have a 06 T&C with 50,000 miles on it and I am going to put new tires on it. What do you think, should I replace the air senser valve stems. now or let it go I just bought the van at don,t know much about the history. It does have the original tires on it. I hear there is batterys in them that can run down.
    Thanks for any advice you can give me
    Jan 2009
    Ohio
    595
    If it were up to me I would replace them. I think they say they last fives years, so you got so time, but while you have the tires dismounted, to me it would make sense to change them. If not in a couple of years when they go bad, you will have to pay someone to dismount and remount again in order to change out the stems.
    01 Dodge Grand Caravan (Sport) 3.3
    New tranny at 99,650 miles
    Currently 123,000 miles
    Sep 2008
    Canada
    405
    Have you priced them? They aren't cheap!
    2003 GRAND CARAVAN SPORT
    1997 RAM 1500 SPORT 4x4
    2003 ALERO
    Jan 2009
    Ohio
    595
    Quote Originally Posted by rabbler View Post
    That's what is nice about the older vehicles, they don't requires special valve stems.
    Dec 2008
    Illinois
    20
    yes I have checked the prices they aren,t cheap but if one goes bad its not cheap to have it replaced a year after you put the new tires on
    Feb 2009
    Victoria BC Canada
    1,927
    Quote Originally Posted by Kscha41 View Post
    yea for Generation 3 and earlier.
    Jan 2009
    Ohio
    595
    Quote Originally Posted by dun4now View Post
    My 01 has regular valve stems.
    Jul 2008
    Cincinnati
    323
    Vehicles with TPMS seem to require that the TPMS be rebuilt when new tires are put on, so says my WalMart (government rule Walmart says they follow). This only replaces orings and other "wear items." I did not replace my TPMS sensors as I expect them to last at least through the next set of tires (10 years seems to be the industry standard).
    2005 T&C Signature Series, 64,xxx miles
    Lots of rust, leaking steering rack, bad rear AC condenser coil, rusted (and replaced) rear brake line. Looking forward to the next failure/defect that this Chrysler will bring into our lives.
    Dec 2008
    Illinois
    20
    Thanks for all the input on the valve stems
    Thanks P E Scott I,m going to go with what you say. Now, I hope were I,m getting these new Harmony tires put on that they can replace them orings.
  1. high pressure ac hose valve
    By pippo in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 07-11-2010, 08:12 PM
  2. Pressure relief valve problem?
    By randys6008 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 01-04-2009, 02:09 PM
  3. high pressure port valve=charger valve???
    By mewant2b in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 09-24-2008, 04:41 PM
  4. Plain Steel wheels accept tire pressure stems?
    By mr_fixit in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 07-26-2008, 12:57 AM
