Fuel Pump shut off after accident?
Results 1 to 10 of 16
Thread: Fuel Pump shut off after accident?
    Oct 2009
    2
    Do the 06 Caravans have a fuel shut off that activates when the car is in an accident?
    Moe
    May 2006
    New Hampshire
    8,395
    Quote Originally Posted by moejr View Post
    Moe
    As a general rule, no, then again, I'm thinking that you're going to have to define "accident".
    2006 Acura TL 6-Speed
    Jul 2009
    Tunkhannock, PA
    430
    Not 100% sure on the Caravans, but a LOT of American made cars have this safety feature. It's not typically advertised. My sisters '87 Ford Escort had this, with a manual switch in the hatch area to re-engage the fuel pump after an accident. My '04 Cavalier also killed fuel flow after being hit with SRS deployment.
    I would assume something as new as an '06 it would be standard feature, to keep fuel from igniting in the engine bay of a crushed engine...
    Of course a minor fender bender should not trip this... so like shippo said, the degree of accident would be a factor here. Both cars the pump was shut down, the damage required towing from the scene
    2005 Kia Sorento LX 4x4 44,000mi
    2003 Chrysler T&C Limited 3.8l AWD 145,000mi Traded in 9/14/11
    2000 Dodge Stratus ES v6 179,000 sold 7/2011
    Oct 2009
    2
    Sone clown wasn't paying attention and pulled out in front of her. She hit him at about 35 mph and took out her whole nose section. Both the wheel air bag and knee bag deployed and when she hit him the van shut right down. No restart was tried as radiator got toasted. Most likely the van will be totalled.
    Jan 2008
    Nova Scotia, Canada
    16,565
    Moe
    From a NHTSA site:
    II. Existing Standard
    Standard No. 301 sets performance requirements for the fuel systems of light vehicles, i.e., vehicles with a gross vehicle weight rating (GVWR) of 4,536 kg (10,000 pounds) or less. The standard, which was issued in the 1970s, limits the amount of fuel spillage from fuel systems of vehicles during and after being subjected to a frontal, rear, or lateral impact test.
    In the frontal impact test, a vehicle is driven forward into a fixed barrier at 48 km/h (30 mph), while in the side impact test, a 1,814 kg (4,000 lb) barrier moving at 32 km/h (20 mph) is guided into the side of a stationary vehicle, and in the rear impact test, a 1,814 kg (4,000 lb) barrier moving at 48 km/h (30 mph) is guided into the rear of a stationary vehicle. The standard limits fuel spillage from crash-tested vehicles to 28 grams (1 ounce) by weight during the time period beginning with the start of the impact and ending with the cessation of vehicle motion and to a total of 142 grams (5 ounces) by weight during the 5-minute period beginning with the cessation of motion. During the 25-minute period beginning with the end of the 5-minute period, fuel spillage during any 1-minute interval is limited to 28 grams (1 ounce) by weight.
    A. Component Performance (Phase 1)
    We explained that our focus in Phase 1 was on developing component performance criteria aimed at shutting down the fuel supply and potential fire ignition sources in a crash to help reduce the occurrence and effects of a fire should a breach in the fuel system occur. Quickly shutting off the fuel flow during or immediately after a crash would eliminate a major fire and fuel source and should, therefore, both reduce fires and limit the spread of fire, if one were to start. Phase 1 would also focus on minimizing the possibility of an electrical spark of sufficient intensity to act as an ignition source. Finally, it would explore other means for reducing fires (e.g., engine fire extinguishers). While these criteria would primarily address fires that originate in the engine compartment due to frontal impacts, they would also help to shut off the fuel flow for all crash modes, including a rollover crash.
    In the ANPRM, we sought comment about component test requirements for fuel tanks, fuel pumps, the vehicle's electrical system, and engine fire extinguishers. We requested information on the performance, cost, and practicability aspects of various systems for shutting off the fuel flow and the electric power. We also requested comments on ways to develop practicable test procedures and to define specific criteria with sufficient objectivity that test variability would be minimal.
    We also explained that we believed that the technology already existed for detecting and identifying conditions when the fuel flow should be shut off. Most new vehicles sold in the United States were already equipped with devices that shut off the fuel pump in any collision that causes the engine to stop. Other vehicles were equipped with inertia switches that shut off the fuel flow and/or the electric current.
    Jul 2008
    Cincinnati
    323
    As I understand it most modern cars only run the fuel pump when needed (for example when coasting in gear and no fuel is needed the fuel pump turns off). So in an accident when the engine would be damaged and/or the lines are cut cutting off the engine the fuel pump would stop pumping. Certainly there is some sort of logic for the car to identify if an accident has occurred but also regular operation of the engine computer should prevent major fuel loss.
    2005 T&C Signature Series, 64,xxx miles
    Lots of rust, leaking steering rack, bad rear AC condenser coil, rusted (and replaced) rear brake line. Looking forward to the next failure/defect that this Chrysler will bring into our lives.
    Jul 2008
    Niles Il.
    10,101
    Quote Originally Posted by PCE Scott View Post
    Mostly true but a little clarification. The fuel pump does run while coasting or else the engine would die out unless the torque converter stayed locked which it does not in chrysler products. It is true that the PCM will turn off the fuel pump when the cam/crank sensors are telling it that the engine rpm is 0.
    '69 GTO drop top
    Apr 2007
    SoCal
    5,296
    There is a rollover valve on the tank to keep fuel from running out the vent lines in the event the van rolls over but, I'm not aware of a cutoff valve other than the check valve in the fuel filler tube.
    Yup, as long as the PCM sees rpms, the pump runs. Fuel pressure will always be there, engine running or not.
    Sep 2008
    Canada
    405
    Something probably shorted and poped a fuse.
    Lots of wiring in the Left front of the vehicle.
    2003 GRAND CARAVAN SPORT
    1997 RAM 1500 SPORT 4x4
    2003 ALERO
    Jan 2009
    Ohio
    595
    I know my ford zx2 has the fuel pump shut off but I have nuver heard or seen anything about the chryslers.
    01 Dodge Grand Caravan (Sport) 3.3
    New tranny at 99,650 miles
    Currently 123,000 miles
  1. 93 Fuel pump
    By tloughrin in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 03-23-2010, 02:15 AM
  2. Interactive Decel Fuel Shut-Off
    By 03LIMAWD in forum 5th. Generation Chrysler Minivans: 2008-2016
    Last Post: 09-19-2009, 10:11 PM
  3. is it my fuel pump
    By joshockey in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-24-2008, 10:07 PM
  4. Fuel pump
    By gibbelstein in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 04-10-2008, 12:24 PM
  5. fuel pump?
    By cf1 in forum 2nd Generation Chrysler Minivans: 1991-1995
    Last Post: 02-02-2008, 09:49 AM
