misfire/hesitation
Results 1 to 6 of 6
Thread: misfire/hesitation
    Jul 2012
    183
    misfire/hesitation
    Occasionally, when driving at low RPMs (between 1000-2000), and I press down on the gas pedal rapidly to about 1/2 or 3/4 throttle, the engine will misfire and hesitate for a moment and I will feel/hear a single "backfire" sound coming from right under the floor. (No check engine light.)
    May 2011
    was in Germany, now Ohio
    17
    How many miles on your van? Also what are the condition of the spark plugs? I had something similar happen and one of the plugs had a chip broke from it. Once the plug was changed - it resolved the issue.
    Apr 2007
    SoCal
    5,296
    May be first signs of a weak fuel pump. Backfiring at the intake usually indicates a lean fuel condition. Could also be partially clogged injectors. Anything that will restrict fuel flow.
  5. The Following User Says Thank You to RIP For This Useful Post:
    toronado455(05-23-2017)
  6. Remove Advertisements
  7. #4
    Jul 2012
    183
    Quote Originally Posted by sniper69 View Post
    Spark plugs last replaced December 2012 at odometer 151724
    Current odometer is around 225000 and condition of Spark Plugs is unknown.
    2002 Grand Caravan Sport 3.3 (Flex Fuel) 215K miles
    1989 Caravan C/V SWB (no longer own)
  8. #5
    May 2011
    17
    Quote Originally Posted by toronado455 View Post
    If it were me, checking the plugs might be one of the first places to start.
  9. #6
    Jan 2008
    Nova Scotia, Canada
    16,564
    Anybody done any work on the engine or to the rear of the engine recently?
