'03 Town and Country Passenger Heat-cold only--blend door issue?
Results 1 to 3 of 3
Thread: '03 Town and Country Passenger Heat-cold only--blend door issue?
    Sep 2009
    4
    The Manual control for the passenger side of our T&C doesn't change the air temp coming out of the heater--fine for summer, but winter is coming and we're in northern Minnesota.
    Any help will be much appreciated.
    What's the easiest way to access the blend door/actuator for the passenger side? Is it found on the passenger side under the dash?
    How much will I need to take apart to find it? I know that I'll need to disconnect the negative battery terminal to prevent being punched in the face by the airbag.
    I've checked some of the other threads that are similar to this--but I haven't found any that specifically said it was the passenger side and where it was located.
    Thanks for any suggestions and help. Thanks for your time.
    Dudley
    Jun 2007
    162
    Here are the steps as listed in the TSB for this problem
    TSB fix for no heat on passenger side
    I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology. I now have over 400 repair articles, TSBs, and wiring diagrams on my blog: http://www.ricksfreeautorepairadvice.com//
    Sep 2009
    4
    Thanks Rick.
    Would you be able to provide any photos or a diagram of what I'm looking for? I've seen some on different forums--but I'm not sure if they're the same as my 2003. The directions are clear, I'm just wondering where the passenger blend door is located in relation to the driver's side door. Thanks again.
    Please reply here and/or to cindy.wishard@gmail.com
    Thanks for the help.
    Dudley
  1. No heat - maybe bad blend door linkage
    By DaveKG55 in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 09-05-2015, 07:24 PM
  2. Blend Door? Blend Door Motor? Fail
    By Chrysler1924 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-15-2010, 06:45 PM
  3. 98 Town Country Lxi AC not blowing cold
    By rjdevita in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 04-13-2010, 09:38 PM
  4. Location of drivers side heat blend door ?
    By colcaravan in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 11-30-2009, 07:24 PM
  5. 2003 Town & Country heat issue
    By Cozmo in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-09-2007, 05:57 PM
Tags for this Thread
