Service Tire System Soon - Message
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
Thread: Service Tire System Soon - Message
  1. #11
    Apr 2007
    San Diego
    5,169
    Wonder if you could measure the signal strength with an RF meter to determine which sensor has the weak battery. Anywho, yours is at the 5 year limit so probably best to change all of them anyway.
  3. #12
    Apr 2009
    Empire State
    3,786
    Quote Originally Posted by RIP View Post
    it might be possible, but it would not be 100% accurate.. (many factors can effect RF signal strength) not to mention that the sensors could be from a mixed batch (different dates / components / factories)
    besides, i'm fairly certain that it's not low RF signal that triggers the warning. Rather, the sensors monitor the battery voltage and at certain level transmit a "code" to the system..
    Since flash9 recently replaced the tires it makes little sense to wait to see how long the batteries will last.. (although, on some TPMS you may have up to 18 months before they start to drop out)
    RE: battery life
    obviously the more hours the van is driven, the more use batteries will be subjected to. that said, lithium batteries can (theoretically) last over 10 years - primarily depending on the "quality" (purity) of the materials used.. and secondly on the capacity / current draw...
    *if mopar (or whoever designed for them) wanted these things to last, they would put a small generator into the sensor (it could easily recharge a small LiION battery or even a capacitor and last far longer)
    but there's no profit in that..
  4. #13
    Jun 2009
    Jefferson City, TN
    3,051
    Seems to me they could have put one of those things in the sensors like some watches have... you know the kind that charges themselves with movement... plenty of movement in a spinning wheel...
    Jeff
    Current:
    Previous minivans:
  5. #14
    Feb 2009
    NW Iowa
    174
    If it makes you feel any better I have the same problem with my 2002 and it went away when the weather became warmer.
    Once it starts up again once it gets cold I will replace all the wheel sensors and see if it corrects the problem.
    But it is still warm enough that it has not dropped the battery voltage in the sensors yet.
    2002 Chrysler T&C bought new end of 2001.
    3.8 L 108,000 avg. fuel eco. 22.4
    2009 Pontiac G8 GT fuel economy not determined yet, currently 22 mpg
  6. #15
    Feb 2009
    NC
    21
    Exclamation Parts Update
    I ordered the Pressure Sensor Monitors for all four tires today from a local O'Reilly Auto Parts store. They estimate it will take a week to get them in-stock.
    I will update again in 7-10 days once I get the parts and have them installed.
  7. #16
    Feb 2009
    NC
    21
    Thumbs up No more Service Tire System Soon Message!
    Purchased four of the Dorman Part Number 974-028 Tire Pressure Sensors on Friday.
    Last night on my way home from work I took the van back to the small tire shop, and we proceeded to replace all four valve stem / tire sensors on the vehicle. The instructions say to wait 20 minutes after pressurizing the tires. After starting the van, I drove home, which is just a couple miles away. At first I was still getting the Service Tire System Soon, message as well as 3 Tire(s) have Low Pressure message. About half way home the Service Tire System Soon, message went away, but the 3 Tire(s) have Low Pressure message stayed lit. When I got home I inflated all four tires to 38 PSI. The 3 Tire(s) have Low Pressure message proceeded to stay on for about another 10 minutes of driving (I was getting concerned) and then the display finally went back to compass and exterior temperature!
    Total cost $140 Parts, $40 Labor, Total $180.
    Not cheep, but a lot less then the dealership wanted to do the work.
    I hope this information will help others in the future.
  8. #17
    Jul 2009
    Plano, TX
    180
    Great info flash9 and MoparChickie!
    Now I know my 09 DGC's TPMS sensor batteries are only good for 5 years....so in 2014....
    - Kevin
    2009 Bright Silver Metallic Dodge Grand Caravan SE 3.3L v6 18k mi
    2001 Stone White Chrysler Sebring Convertible Limited 2.7L v6 85k mi
    "If you had access to a car like this, would you take it back right away?"
    "Neither would I!" - Ferris Bueller
  9. #18
    Feb 2009
    NW Iowa
    174
    I am betting in the next couple of weeks once it cools off ours will start setting service soon again and I will do as you did and replace the sensors. I am betting though that I will be able to put the sensors in myself by lower an object along the side of the tire to break the bead off and replace sensor and refill tire.
  10. #19
    Feb 2009
    NC
    21
    Quote Originally Posted by struggle View Post
    ... I am betting though that I will be able to put the sensors in myself by lower an object along the side of the tire to break the bead off and replace sensor and refill tire.
    You very well might be able to do this. On the first tire we tried this, but struggled to get our hand inside the tire in order to install the tire pressure sensor.
    After working at it for a few minutes, the mechanic said, the he11 with this, and went ahead and used the tire mounting machine, and separated one side of the tire from the rim. This made it a lot easier to mount the tire pressure sensor per the instructions.
    I guess if you try this and it does not work, you can always call some tire shops to see what they would charge. For me, the $40 was money well spent.
  11. #20
    Feb 2009
    NW Iowa
    174
    It will be a try and see thing for sure. Glad you got yours taken care of. Did you relearn the sensors with the magnet?
  1. "Service Tire System Soon" message. Need help!
    By RayFaatz in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 05-09-2009, 08:21 PM
  2. Air pressure system service
    By struggle in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 03-10-2009, 11:31 PM
  3. tire sytem message
    By chris f in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-03-2009, 10:35 AM
  4. How to reset the service soon message on the console
    By LinerJoe in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 08-12-2008, 02:34 PM
  5. Disable "tire system" message?
    By jshatch in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 10-14-2007, 10:35 AM
