2005 T&C 3.8 Spark Plugs
Results 1 to 8 of 8
Thread: 2005 T&C 3.8 Spark Plugs
    Apr 2012
    Kansas
    203
    Itís time to change the ole spark plugs. My factory shop manual calls for Champion brand RE14PLP5 plugs. When I check with Auto Zone it lists a Champion part number 7440.
    This is a copper core fine wire platinum plug. Auto Zone sells them for $5.29 each. For six that would be $31.74.
    My questions are:
    1) Is this the correct plug? I'm not into gimmicky plugs.
    2) What, if any lubricant goes on the plug threads?
    2005 Town & Country Limited
    Jun 2009
    Vermont
    1,168
    Quote Originally Posted by Crashmaster View Post
    Yes, that is the OEM plug.
    None. The threads have a special plating and do NOT require any anti-seize.
    2009 Dodge Grand Caravan SXT (3.8) 200,000+ miles
    2001 Dodge Grand Caravan Sport (3.3) 250,000+ miles
    2003 Dodge Grand Caravan eL (3.8)
    Previous Chrysler Vehicles: 1995 Dodge Caravan (3.0), 1993 Dodge Caravan (3.0), 1986 Chrysler Lebaron GTS (2.2), 1963 Plymouth Valiant (170ci)
  4. #3
    Mar 2017
    14
    Anti-seize on spark plug threads is generally good practice just use a small amount. Although probably more important is using compressed air to blow dirt off the heads around the spark plug before removing old ones.
  5. Remove Advertisements
  6. #4
    Jan 2015
    TEXAS, USA
    4,030
    Quote Originally Posted by rbrat View Post
    As stated by georgef, no anti-seize needed on those spark plugs. Modern spark plugs already are pre-coated with a special coating, adding any other anti-seize product is not recommended.
    Let's not confuse people asking for advice.
    2012 Town & Country
    2006 Dodge Grand Caravan. 317,000 + Miles. -SOLD-
    Current Minivans I own.
    LEVY --UNKNOWN MEMBER--
  7. #5
    Mar 2017
    14
    Haha, no confusion intended! Maybe I should have offered my opinion this way: Sure it's not required. Anti-seize won't hurt anything but use at your own risk. I think the main reason plug manufacturers don't want people lubricating threads is because it can increase the risk of some knuckle head over tightening and stripping threads. Or getting it on the electrode (use small amount and don't over tighten and you will be fine) Or dry **** them in there like these guys want you to
  8. #6
    Jan 2015
    TEXAS, USA
    4,030
    That is correct, but I wouldn't call them "knuckle heads", you might quickly get some enemies here.
    Stating that using of anti-seize is generally a good practice might came back and haunt you!
    2012 Town & Country
  9. #7
    Jun 2014
    986
    I use some when I change out our plugs, even though its not needed. As you said, I only use a little and have never had a problem of them coming lose or over torquing them.
    Quote Originally Posted by LEVY View Post
    Your correct.
    01 DGC EX w/ 3.8L engine w/205K+. Bought used in Sep. 2003 w/36K
    07 Toyota Camry w/2.4L engine w/112K+. Bought used in Nov. 2009 w/36K
  10. #8
    Jan 2014
    DFW, TX
    75
    I used just a dab when I did mine ~ 30k/3yrs ago; seems to be holding up A-OK.
    Albert
    Current:
    '01 T & C Limited 3.8 bought 10/2007 63k now at 150K!!!
    Retired:
    '96 Grand Caravan LE 3.8 - totaled in flood 10/2007
    '88 Grand Voyager woodie LE 3.3 - rear-ended/totaled/bought back for $88 dollars/2 more years til ABS failure
    '78 Magnum XE 360/727 red/cloth - thanks for the memories
    '78 Magnum XE 360/727 black/leather - rust never sleeps
    '73 Dart Custom 225/904 landau/cloth/see-thru floorboards - my first Mopar 200 to the old lady/100 to the inspector
