2007 T&C dead
Results 1 to 2 of 2
Thread: 2007 T&C dead
    Feb 2017
    1
    2007 T&C dead
    My van was running fine then went out to leave it started then put in gear it died. Started it again let it run a couple minutes put it in gear it died. Now I have no dashlights, wont start, keys wont do anything. If I manually turn on head lights they work. Is this a computer problem
    Oct 2007
    Altamont, KS
    528
    17
    I had a similar problem. Turned out to be a short in the power door harness. I disconnected it and it started right up after pulling the IOD fuse. I suspected it since I had just tried repairs on it the week before. Try resetting the computer by disconnecting the battery or pulling the IOD fuse. Give it about 15-20 minutes.
    2005 T&C Touring. 3.8L Midnight Blue. 197K Still Runs
  4. The Following 2 Users Say Thank You to katoranger For This Useful Post:
    Caraman99(02-17-2017), JC1(02-17-2017)
