Transmission-Code P083b and P0706
Results 1 to 7 of 7
Thread: Transmission-Code P083b and P0706
    Jul 2010
    Jesup, GA
    93
    OK. So, yeah, it's been forever since I posted because we sold our beloved 2005 T&C several years ago (WHY???!!!). But never the less-we bought a Volkswagen Routan SE (YES_I know this is a T&C forum). 2010 model with a lot of nice features. I did my research (I thought) and decided it was nothing more than a T&C with a VW badge on it. All the powertrain parts are Chrysler. The interior and electronics are VW.
    Short story-I broke a valve spring, bent the valve and have been fiddling with it along and along. Well I finally got the valve and spring replaced the other day which was actually pretty easy Thank God for the engineer that came up with Over Head Valves (OHV). Still had to remove the head to change the valve, but I didn't have to lose my engine timing.
    Anyway, fired her back up and she purred like a kitten. Buuuuuuuuuuuuutttt....it's stuck in LIMP mode and I get the codes listed in the title. Funny thing is, when in limp mode, all the gear indicators have boxes around them. Mine does that, but if I turn off the van, remove the key and open the door (simulate getting out), close the door, then try to start, switch QUICKLY to R or D, it will work for just a short period and display the current gear I am in.
    So, my thought are the 083B code could be the main culprit leading to the 0706 code. Has anyone else has anything like this happen? Ideas? I hate to take it to the VW place as it is 1 hour and 15 minutes away and I'd have to tow it. Plus, I had a not so pleasant experience with them. They diagnosed my broken spring as a bad catalytic converter.
    And thanks in advance.
    P083B-LC pressure switch rationality This is a pressure switch for the transmission, Which you have 3. If one of the pressure switch is open or closed at the wrong time when in park or neutral,The transmission goes into limp mode , this is where you have limited gear operation,This problem code is related to a fault in the Transmission solenoid or TRS assembly
    Read more: https://www.autocodes.com/qa/20523/w...-dodge-caravan
    P0706 code is a generic powertrain code related to the transmission. This code is non-emission related. The transmission range sensor circuit is not communicating correct data to the engine control module (ECM). This code only applies to vehicles with an automatic transmission.
    2010 VW Routan SE
    All Chrysler parts, that's why I come here for info
    (SOLD)-2005 T&C Touring W.P. Chrysler Signature Series
    3.8 V6, most bells and whistles.
    Jan 2014
    Peoria, IL
    1,017
    Since you just did the engine work, it seems likely that something electrical is disconnected or was damaged during the engine work. It seems to coincidental that your trans would break while the car was sitting and you were working on the engine.
    2011 Town and Country Touring Black w/heated Cloth seats, Uconnect group
    2013 Honda Odyssey EX-L (Wife's car)
    Jul 2010
    Jesup, GA
    93
    I agree and thought the same thing. But I have been through this thing 100 times. And to work on the engine doesn't require touching anything on the transmission. Reckon I'm heading to the dealer soon to see what they can tell me.
    2010 VW Routan SE
    Jul 2010
    Jesup, GA
    93
    Well, not that anyone is really following...but I pulled the cover off the transmission. Manually moved the shifter under the cover a few times. Put it back together, Filled it with fluid and it will now change through the gears (P R N D) and indicate the proper gear. But it still doesn't shift correctly. The only code I have now is the P083B which seems to be a pressure switch-somewhere.
    Will update if I find the problem.
    2010 VW Routan SE
  7. The Following User Says Thank You to pmassey31545 For This Useful Post:
    LEVY(02-20-2017)
  8. #5
    Jul 2010
    Jesup, GA
    93
    So. I ordered a pressure switch due to code P083B. Installed it today and still getting the code. So, I guess it's going to the VW dealership sometime next week. I think it's something electrical but I have checked everything over and over and over. I am finally at my wits end on this one.
    2010 VW Routan SE
  9. #6
    Jul 2010
    Jesup, GA
    93
    Well, talking to myself again.
    Took it for another drive today just to make sure. When I start the van I can switch it to drive or reverse and it seems fine. For about the first 15 seconds I can cycle through the gears (1-6) with the manual shift feature. But every time it will 'clunk' and then it's stuck again. I actually put it on jackstands and let it run for 12 miles just to se if something would magically happen-but no.
    Anyway...............
    2010 VW Routan SE
  10. #7
    Jan 2008
    1,981
    235
    What was the outcome?
