Changing Plugs on 2000 grand caravan 3.3L
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Changing Plugs on 2000 grand caravan 3.3L
    Aug 2004
    1
    Are there any tricks to changing the rear spark plugs on the 3.3l engine? This is in a 2000 Grand Caravan.
    Aug 2004
    40
    Not a direct answer to your question, but there are Chilton and Haynes manuals available for that model year now. They may give you some guidance.
    * ijhutch *
    Nov 2003
    936
    No tricks. You have to move the alt. to get #1, the rest of the rears are from underneath. THe fronts are easy. Other way is to remove the plenum which isn't that hard. If you do that I'd go ahead and do VC gaskets since you'll be there already. I'll be doing that on my 99 since at 200+k it will be getting it's 2nd set of plugs and I might as well lol
    LArry
    Jul 2003
    High Ridge, Missouri
    4,760
    Larry is right, pretty well. I have gotten to the #1 w/o moving the alternator however it is easier that way. Removing the plenum is a good idea also, so you can clean it up inside.
    Buy the FACTORY SERVICE MANUAL if you are buying any manuals. The other ones are, well, I really can't repeat it on here, what I think of them. You can find FSM on e-bay all the time.
    The 2001 plenum makes it alot easier to do on the 4th gen vans. All plugs from the top.
    Avatar: EconoVoyager Concept
    Nov 2003
    South Hills of Pittsburgh, PA
    1,298
    My wife's 98 3.3 needs plugs I think.
    I am paying somebody to do it.
    I will do the wheel bearings, even the serpentine belt... but I am NOT going after those back three plugs.
    I guarandamntee I will break something in a fit of anger.
    Chas
    Chas Stokes
    2000 Saturn SL1 "ZUUL"
    2002 Hyundai Elantra (Stolen ) "ZUUL24"
    Mar 2004
    6
    Just thought I would throw my two cents in. My manual says to remove the wiper module/cowl. Haven't done it yet on mine but it does look relativly easy to do. I believe a Hayes manual also shows this procedure to change the rear plugs.
    Sep 2004
    Winnipeg, Manitoba, Canada
    450
    i have long arms and fingers so getting underneath my van and changing the plugs was easy (just make sure your exhaust is cool first, i learned that the hard way *blush*
    Sep 2004
    5
    i pull the plenum. but was also able to do it the long finger/arm way.
    but i pulled the plenum the second time.
    Dec 2004
    TX
    4
    I went the route of pulling the plenum and cowl. Having that cowl out of the way was a *big* improvement. It just looked like there was too much stuff in the way to go from the bottom w/o a lift. I hope I never have to do it again though.
    Nov 2003
    1,298
    I know I am going to get slapped for this... but...
    What the heck is the plenum???
    Chas
    Chas Stokes
  1. Changing valve cover gaskets 2000 grand voyager se
    By billandcat in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-29-2008, 01:05 PM
  2. '00 Grand Caravan ES 3.8L - Still has original plugs?!
    By Chrysler1924 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 07-26-2008, 06:31 PM
  3. Changing Air Filter In 2007 Grand Caravan
    By mdamico in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 01-31-2008, 12:45 PM
  4. Changing Oil On My 2007 Grand Caravan
    Last Post: 01-29-2008, 02:33 PM
  5. Tune up 1997(changing plugs) Dodge Caravan
    By SD2NJ in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 03-06-2007, 03:30 PM
