1997 - Trac off light, driving very slow in snow
Results 1 to 8 of 8
Thread: 1997 - Trac off light, driving very slow in snow
    Oct 2009
    Aberdeen, SD
    43
    This morning, I drove into work thru some snow - probably up to 6-8" drifts and a few inches on the ground. It seemed to be driving slower than it should. I parked it for a few hours, and when I drove it, it was almost like it was frozen to the ground, and was slow taking off. After stopping for traffic lights, I had trouble getting moving- almost like the brakes were on. Driving thru a slight curve was similar - it wanted to pull into a slight skid. I was also having trouble building much speed beyond 20-30 mph, and the engine seemed to be working too hard. I also noticed the Trac Off light on the dash.
    Any thoughts? Almost sounds like transmission and or brake issues. I haven't checked the fluid yet - I want to pull into a heated garage first.
    1997 Chysler T&C LXi --130,000 miles
    Oct 2009
    Aberdeen, SD
    43
    Update: Judging from the tracks in the snow, the driver's rear wheel is locked. My first thought is to set/release parking brake a few times to see if it helps release it, on a whim (I don't ever use the parking brake).
    Dec 2014
    80
    Sounds like you may have a seized caliper. You may also have ice build-up on it since you were driving through deeper snow. If it was hot when you parked it, the ice may have built around it while it sat and cooled off. Either way, you need to have it checked out.
    The "Trac Off" light tells you that traction control has been disabled. Due to the brake problem, you MAY be having an ABS issue. The Traction Control system uses the controls of the ABS system to apply/release the brake pressure to the spinning wheel (on the front) to equalize the slip between the wheels. It may have felt like it was dragging because it was......and it was making itself worse due to the input from the wheel sensors.
    Plan on replacing one or more calipers and check the codes at O'Reilly (or the like) and see if there are any ABS codes.
    May 2006
    New Hampshire
    8,379
    Quote Originally Posted by BILT4ME View Post
    I don't believe the Gen 3 FWD vans had rear disc brakes.
    Dec 2014
    80
    Quote Originally Posted by shipo View Post
    Yeah, you're right...DUH!!! on me! I drive a 98........
    Could have melted water get into a brake DRUM and turn to ice on the rear. Either way.....get it checked out. May be a broken brake spring, faulty e-brake mechanism, or a variety of others.
    Please post your solution.
    Jan 2015
    TEXAS, USA
    3,894
    Yeah, you're right...DUH!!! on me!........
    Could have melted water.......
    Melted water?
    How about another DUH!!! for you?
    2012 Town & Country
    Current Minivans I own.
    LEVY --UNKNOWN MEMBER--
    Dec 2014
    80
    Quote Originally Posted by LEVY View Post
    Melted water?
    Darn! Can't get a brake here caan eye?
    Yes, melted water. Similar to solid rock.
    OK Let's start over:
    Ya got stuff not working under the car....... Go look........
    Oct 2009
    Aberdeen, SD
    43
    I had the shop look at it, as learning about drum brakes in sub zero conditions is not a good learning environment for me.
    2 new wheel cylinders, two drums turned, and one new shoe, if I recall correctly. Back on the road,
