Intermittent no start
Results 1 to 10 of 14
Thread: Intermittent no start
    Feb 2016
    9
    I've got a 2010 T/C 3.3 liter. I've got an intermittent no start issue. About 2 or 3 times a month it will spin over and not start ( I assume ECM controlled). It cranks endlessly until you turn off the key switch. Wait about 5-10 seconds to clear the brain fart. Try to restart and it then starts w/o a hitch and runs perfectly after that. I just don't want to get stranded w/ a no start issue if it finally decides to quit. Anyone else run into this problem?
    Jan 2015
    TEXAS, USA
    3,152
    Sounds like your starter drive (bendix) is going out.
    Replace the starter drive and you should be ok.
    Not ECM related at all.
    2012 Town & Country
    Current Minivans I own.
    LEVY --UNKNOWN MEMBER--
    Feb 2016
    9
    Thanks Levy, will check into that.
    Feb 2016
    79
    If the starter engages and cranks the engine as it should but the engine doesn't start at times, then the problem is not with the starter... Perhaps a TIPM fuel pump relay problem?
    Jan 2014
    Peoria, IL
    909
    Quote Originally Posted by invader View Post
    That was my first thought as well.
    2011 Town and Country Touring Black w/heated Cloth seats, Uconnect group
    2013 Honda Odyssey EX-L (Wife's car)
    Jan 2015
    TEXAS, USA
    3,152
    You guys are correct if the engine is actually cranking. Probably I misunderstood, I thought the starter was freely spinning but not the engine.
    Marked1, on modern vehicles, if engine is cranking but fails to start, starter will keep cranking for a few seconds even if you release the ignition key, as a matter of fact, when turning engine on, you just turn the ignition key to the starter position until the starter engages, then release it and it will keep cranking until engine starts.
    So, you only have one problem, your vehicle fails to start, the other issue (starter keeps cranking) is a normal feature of your vehicle.
    2012 Town & Country
    Jan 2016
    Ne
    59
    That's why you heard about those Toyota's not shutting off with the key, computer controlled, our lives are in the hands of computers...
    Quote Originally Posted by LEVY View Post
    2010 STX 3.8
    Feb 2016
    9
    And to clarify, engine spins over but no start. intermittently. Good info, THX.
    Jan 2016
    Ne
    59
    No spark or no gas.
    2010 STX 3.8
    Jan 2015
    TEXAS, USA
    3,152
    Quote Originally Posted by ShieldArc View Post
    No spark or no gas.
    WOW!
    How about not enough oxygen? Happens more often than people think.
    2012 Town & Country
