Brake Lights Out
Results 1 to 3 of 3
Thread: Brake Lights Out
    Jan 2009
    Central VA
    42
    Brake Lights Out
    '00 Grand Voyager, all brake lights are out, bulbs are good. I'm on vacation with my family and am trying to spend my time efficiently. Is there any chance that the brake light switch is not the fix?
    --John K.
    2000 Grand Voyager 3.3, 135k miles, original transmission
    1989 Grand Voyager 3.0, gone but not forgotten
    Sep 2007
    Solar Power design capital of the World: Toledo
    80
    2
    Yes, it could be the switch that runs the emergency flasher, as all brake wires go thru that switch too, intermingled with the turn signal wiring.
    I would guess you need the 4-way flasher switch replaced if the brake switch isn't working.
    You could test the brake switch by driving 45 MPH, engage cruise control, then see if the cruise control goes off when you press the brake pedal. If that works, the brake switch is good and the 4-way switch is bad.
    Let us know what you find out. Good luck my friend.
    John
    99 Expresso 3.3L, 169K miles & transmission died! My van is now gone , but I will help answer what I can.
    Jan 2009
    Central VA
    42
    Good idea about testing the switch via cruise control operation.
    It was the switch. Took about two minutes to fix; the switch was $20.
    Thanks for your help.
    --John K.
  1. Brake and ABS warning lights are ON in my 03 T and C
    By gbmarine in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 12-24-2009, 08:17 PM
  2. No brake Lights!
    By FarmerSid in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 10-06-2009, 02:56 PM
  3. Brake lights?????
    By rattlehead714 in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 12-12-2008, 01:26 PM
  4. No brake lights
    By friscovoyager in forum 3rd Generation Chrysler Minivans: 1996-2000
    Last Post: 02-20-2008, 10:53 PM
  5. Brake and ABS lights on
    By Matt in forum 4th. Generation Chrysler Minivans: 2001-2007
    Last Post: 09-11-2006, 08:34 PM
